Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: custom operating system files
  1. #11
    If they are not installing then there is something going wrong with your install...
    are you logged in to Windows as Admin...?
    are you specifying an install folder other than the default...?
    try this: when you install, on the install .exe do rightclick->Run as Administrator
  2. #12
    Oct 2011
    ill try that joe
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
  1. Custom operating system
    By Harrismarine in forum Custom Operating Systems
    Last Post: October 16th, 2009, 05:02 AM
  2. Why run a Custom Operating System???
    By RacerChris in forum Custom Operating Systems
    Last Post: November 11th, 2008, 11:45 AM
  3. custom operating system nos
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: June 4th, 2007, 01:33 PM
  4. 98 Custom operating system...
    By 98SS2836 in forum Custom Operating Systems
    Last Post: March 19th, 2007, 11:44 AM
