Results 1 to 7 of 7
Thread: 2006 6.0 single turbo not revving up
    Jan 2011
    Default 2006 6.0 single turbo not revving up
    hello ,
    i just got my new 2 bar mapsensor in, scaled right and it reads right.
    the ecm has been flashed to os 03150003 and using the proper tac module and pedal.
    if i try to rev the engine it just bogs, i havent done any logging but here is my tune.
    im not sure if i missed something.
    thanks for your help
    Matt
    You're failing the MAF, but have the MAF DTC's in C6001 set to Not-Reported, so there will be no MAF DTC...
    set those to 1-Trip or Non-Emissions;
    ( without a MAF DTC the PCM will continue to use the MAF, even when it is not present (it calculates what it thinks the MAF should be reporting and used that) )
    Also, you disabled CL/LTFT but you still have STFT SOL (semi open loop) still enabled by having stoich cells in B3647 and B3649.
    Jan 2011
    Thanks Joe,
    I changed the maf dtc's to non emissions, but i cant find B3737 and dont know exactly what you mean by the last post.
    sorry, im dutch
    Matt
    Sorry, typo, I meant to write B3647.
    In your tables B3647 and B3649, there are cells whose value is EQR 1 (i.e. this is the stoichiometric fueling value, corresponds to the stoichiometric AFR)...
    for any cell that is EQR 1 in those 2 tables, the COS will perform STFT trimming when hitting those cells during OL... this has been named Semi Open Loop (SOL)...
    to avoid this (because you want the wideband O2 sensor to report the untrimmed lambda) you must change the 1.0000 to 1.01 or 0.99... (by not being equal to exactly 1 causes the COS to now avoid doing SOL STFT trimming).
    Jan 2011
    Thanks, got that to work, now to work on the timing map, thanks again!
  1. LQ4 single turbo e85 cannot make it idle... Help..
    By carlsonauto in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2012, 07:47 AM
  2. 902hp Common Rail Dodge Single turbo FUEL ONLY!!
    By 2007 5.9 in forum Cummins 5.9L
    Last Post: October 9th, 2011, 04:22 AM
  3. LMM revving out when kicked down
    By tddmatt in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 1st, 2011, 05:59 AM
  4. 2006 Silverado Turbo. . Really need a COS.
    By hotrod in forum Custom Operating Systems
    Last Post: January 25th, 2011, 12:54 PM
  5. Revving past 8000+ rpms
    By robz in forum Gen III V8 Specific
    Last Post: November 15th, 2009, 08:51 AM
