my current setup is a 2012 Camaro 416 LS3 with the flex fuel system added.
what I am wanting to do is run a 300 shot Dry kit.
so will the COS pull timing from my flex fuel tables when I would be spraying?
ex. if I end up getting E70 instead of E85 my sensor would adjust the spark tables to the right E% and the nitrous would pull spark from their, hope this makes since
