Results 1 to 10 of 12
Thread: 05 Silverado 5.3 Ol/CL afrs dont make sense
    Feb 2015
    Unhappy 05 Silverado 5.3 Ol/CL afrs dont make sense
    Working on a cammed 05 5.3, tuned the maf and ve seperatly in ol using wb02 with everything +-3%. Set tune to CL with ltfts enabled and the afrs are way lean and when it goes to closed loop. Wot is fine still. Cruising is okay. Idle is weird. Stft are -2 to 3% in the short log I ran. Nb02s look lazy at idle and if I highlight and average them they are in the higher 500s. When restarting the truck its in the mid 14s until it switches over. Switchpoint is at 450mv across the board. The tune is work in progress but I wanted to get it running decent at for a friend. I will post a log and copy of the tune when i get a chance to log it again and set up my pids and dash alittle better. In tge mean time, any thoughts?
    Post latest tune file.
    Feb 2015
    Will do tonight
    Feb 2015
    ModifiedTune2_newgears_OL_VETUNING_0033.ctzLIGMAN_OL VE Tuning.efiFINAL_TUNE.ctzLIGMAN_FINALTUNE.efi
    1st tune- open loop ve
    2nd-ve ol
    3 final tune trims enabled
    4.log before my battery died on the computer (ntk wideband disconnected) afrs were from his aem wideband which I didn't have any expressions for which is why I used my ntk for the tuning
    Tune isn't finished but just got it so its driveable. The tune was originally a tune from black bear but it was kind of a pain going back and forth and waiting for revisions so I decided to tackle it myself, so most of the trans tuning is theres.
    Feb 2015
    I didn't do any calc vet etc, figured the results would be the same in the end using the wideband and tuning seperatly in OL
    Feb 2015
    Any thoughts?
    I'm still looking... so FINAL_TUNE.ctz is the current tune in the PCM...?
    Feb 2015
    Correct
    Can you log these pids instead, see attached, copy attached file to Documents\EFILive\V7.5\PIDs
    and then on PIDs tab in scantool, open that file (to select those pids).
    Feb 2015
    Do you want the truck still set in closed loop? Just as it is?
  1. EFILive's explanations do not make sense
    By Black6spdZ in forum Cummins 5.9L
    Last Post: June 18th, 2014, 12:36 PM
  2. AFRs
    By pormgb in forum Gen III V8 Specific
    Last Post: November 12th, 2011, 10:00 AM
  3. Super N00b Looking to make sure i dont mess anything up...
    By cyipher in forum Gen III V8 Specific
    Last Post: August 16th, 2011, 03:09 AM
  4. Scenning just AFRs
    By oztracktuning in forum General
    Last Post: May 14th, 2006, 11:12 PM
  5. Does this make sense?
    By turboberserker in forum Custom Operating Systems
    Last Post: February 2nd, 2006, 04:01 PM
