Results 1 to 6 of 6
Thread: Access violation trying to open file to flash
    Apr 2005
    Default Access violation trying to open file to flash
    My patience is wearing very thin with this. I have uninstalled the software completely, and reinstalled version 8.... opens the file fine, ready for flash. Problem is, the definition files that fix several issues with several tables are installed in the 7.5 folder. So I have to install 7.5, once I do this and place the new .ctz files I was given to correct the table issues, I am right back to where I started with the access violations. What's next?
    Apr 2005
    In further testing.....the two updated files for the E92 I was given is causing the crash.... a clean install of V8 and 7.5 without updating the .ctz files and it will flash. Problem is the tables are labled wrong so I can't properly tune.
    Apr 2005
    These axis don't look right....looks like the RPM should be on the 'y' axis??
Name:	Knock threshold axis.JPG
    I pm'd Paul.
    Quote Originally Posted by Jason S. View Post
    Pretty sure it is correct, this is what it looks like with the axis swapped.
    Apr 2005
    ok, anything on the crashing issue with the updated .ctz's?
  1. Access Violation At Address
    By shotgunbob in forum AutoCal
    Last Post: March 31st, 2015, 07:11 AM
  2. Access Violation
    By lafinrat in forum FlashScan V2
    Last Post: October 8th, 2013, 08:29 AM
  3. Access Violation
    By MSURacing in forum FlashScan V2
    Last Post: July 16th, 2010, 09:50 AM
