Currently known issues and possible workarounds for the August 27, 2015 Public Pre-Release of the EFILive Software and Firmware
Download the current/stable release software here: http://www.efilive.com/latest/cat/download-efilive
Download the public pre-release software here: https://forum.efilive.com/showthread...ic-Pre-Release
Public pre-release software versions:
- Software: V7.5.7.292
- Software: V8.2.2.285
- FlashScan/AutoCal firmware: V2.07.90
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
The V8 scan tool [F3: Data] display does not allow the type of units to be selected for each PID being displayed.
Workaround:
None. Will be fixed in the next update.
Issue 3:
The V8 scan tool [F4: OBD] display may display spurious DTCs for the E86 platform and/or may not display the SRT results for one or the other controller when both an ECM and TCM are present in the vehicle.
Workaround:
