Results 1 to 10 of 11
Thread: running rich
    Jan 2011
    Default running rich
    Hello,
    Im new to the whole turbo tuning, i have a dyno but not set up yet. i set up a cos with a 2 bar map sensor, that all seems to read ok.
    i use the stock ve table and went trough the whole tutorial to set everything up.
    it idles at a afr of around 7-8 and when driving its in the same range. if i lean it out a bit it wont idle.
    it hesitates when accelerating and i cant go wot.
    what am i missing?
    Matt
    Hmmm, AFR 8 is way rich...
    Are you getting an immediate MAF DTC...?
    Jan 2011
    I would have to check. I will let you know
    Thanks,
    Matt Derks
    www.derkscustomcars.com
    Lifetime Member darcy's Avatar
    Feb 2012
    Does it really only have 21lb injectors in it?
    If you have no MAF I would set C2906 to "1"
    Jan 2011
    for now it does, so it shouldnt be running rich lol. i have some bigger ones on order
    i will try that
    Jan 2011
    [IMG][/IMG]
    That's at idle. I think I have to setup my lc1
    Thanks,
    Matt Derks
    Quote Originally Posted by darcy View Post
    Good point... this make MAF fail immediately.
    Quote Originally Posted by derkscustomcars View Post
    [IMG][/IMG]
    Yes, if you want to see AFR, but for tuning use Lambda and/or EQR...
    avoid AFR at all costs...
    the correction multiplier is easy: CALC.WO2BEN = {GM.EQIVRATIO} * {EXT.WO2LAM1}
    you can get this from the calc_pids.txt file from the Calc.VET thread: calc_pids.txt
    Jan 2011
    Thanks guys. That's what I kinda figured now. But no sense doing anymore tuning. The 21lb injectors only support about 330 hp
    Thanks,
    Matt Derks
    yes darcy has a good point on your injectors.
  1. Why am I running rich during PE?
    By n8dogg in forum Gen III V8 Specific
    Last Post: August 4th, 2011, 09:31 AM
  2. 5.7 running rich.
    By DmaxHawk in forum Vortec V6/V8 Specific
    Last Post: January 21st, 2009, 06:40 AM
  3. COS3 running rich
    By southern in forum Custom Operating Systems
    Last Post: September 17th, 2008, 04:56 AM
  4. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
  5. It's running a little rich
    Last Post: January 23rd, 2007, 02:30 PM
