TBSS #3.efi
Here is a log at O.T. I also took it for a drive on this log. 1-2 shift is HARSH. Sorry it took so long. I have been really busy. Thanks
TBSS #3.efi
05 lly 11.69 @ 115mph. stock motor, s475, 40% nozzles, lbz reg
685hp/1100ftlb
11 Cruze 1.4L turbo
It this the tune file the log was taken from: TBSS stock ECM tune ls7 maf.ctz
685hp/1100ftlb
11 Cruze 1.4L turbo
Ok, here is the pid list to use, copy to Documents\EFILive\V7.5\PIDs.
Also, try flash the attached .ctz and take a new log from this.
Ok will do first thing in the morning. Thank you
685hp/1100ftlb
11 Cruze 1.4L turbo
Also, something wrong with your LC1 in the log...
update your V7/V8 software (and V2 firmware) from here: Aug-27-2015-EFILive-Public-Pre-Release
