Results 1 to 4 of 4
Thread: E85 conversion
    May 2008
    Default E85 conversion
    I'm converting my ls1 turbo to E85 , ive read many threads and articles on the best way to do it,
    if I change the ratio for stoich to 10-1, will all the other tables compensate as they are in lambda?
    Then just make PE .7 odd to suit the E85?
    Is there any other tables that may be out?
    the o/s is 1290003 if that helps
    Any idea welcome thanks.
    Yes, correct.
    PE set to lambda 0.7 implies you're running boost... 0.7 is rich for boost, you can go as lean as 0.76 (if VE and MAF are correct).
    May 2008
    Ok so I have got it running on E85 on 10 psi but there is no way it will take anything richer than .80 lambda , making 20rwkw more than 98 with a few extra degrees of timing, but every time I try to richen the mixture it misfires. Is there a chance that the e85 in winter ( from a service station in Melbourne) is not quite e85? It definitely seems to like to make power leaner that it's supposed to be. It normally runs 11.5( .78) afr on 98 with around 12 degrees of timing ( stock ls1 bottom end, mild cam ) . I would have thought it should take being a lot richer on e85 but it doesn't seem to like it .
    Post your tune file and log file.
  1. Chev/Holden 1.4L Cruze E85 FlexFuel Conversion
    By GMPX in forum E78, E83, E84 PFI ECM's
    Last Post: October 15th, 2014, 08:58 AM
  2. Tuning for E85
    By picnic_george in forum General (Petrol, Gas, Ethanol)
    Last Post: March 26th, 2013, 08:12 AM
  3. 2008 Boosted 950 hp E85 conversion LS3 Corvette lean PE pulse
    By mowton in forum E37, E38 & E67 PFI ECM's
    Last Post: July 9th, 2012, 09:45 PM
  4. E85 Conversion
    By duramax2500hd in forum Petrol / Gas
    Last Post: June 15th, 2010, 01:12 PM
  5. E85 Os???
    Last Post: July 3rd, 2007, 02:15 AM
