Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: October 2015: EFILive Public Pre-Release
    Default October 2015: EFILive Public Pre-Release
    Both the V7.5 and V8 software were updated in this release, you must update both software packages.
    Release Notes:
    Whats New
    IMPORTANT
    The Auto-Lock implementation for E39, E92 and E98 controllers requires that tuners and customers upgrade their AutoCal and FlashScan firmware to V2.07.86 or later. The upgrade is required to prevent *.ctz and *.coz tune files created using this pre-release (or later) from being used with older software or firmware.
    Tuners: If you update your software and firmware and attempt to deliver new tune files to your customers, then your customers must also update to the following versions (or later):
    • V7.5 Software: V7.5.7, Build 288
    • V8 Software: V8.2.2, Build 281
    or they will not be able to flash those new tune files. Existing/old tune files will continue to work normally with the new software.
    Existing tune files will continue to work normally with the new software.
    Known Issues
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the Known Issues thread.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 296
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 287
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.92 (Oct 26, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Installed and running! Anything specific you want tested?
    By the way.... Was hoping for 2016 T87 OS # 24278443......
    Chuck CoW
    Quote Originally Posted by Chuck CoW View Post
    I left it out just to annoy YOU Chuck
    Nov 2009
    Thanks Ross!
    -Kory
    http://www.PPEI.com/
    Default You're not annoying me.....
    You're like my little Brother.... I know just how to turn your screws to make you crazy.
    Purely for my own entertainment!
    But, that doesn't mean that I don't love you like a brother.
    Besides, I came up with a good workaround for that OS anyway....
    Chuck CoW
    No blood was boiled with your comments Chuck, its all good.
    Strange enough, I updated everything in the middle of the night.... All went well.
    This morning I tried do datalog an LS1 via serial wideband.... Something I do pretty much every day.
    Non of my ben factor pids would work and my ben factor map (that I use every day) was messed up.
    While I agree I might be nuts, I did use it every day (and yesterday on the same car) without any issues.
    Anyone have any similar issue......
    Chuck CoW
    Chuck CoW
    For anyone else having the same or similar issues, an updated sae_generic.txt file has been posted in the known issues thread to fix this problem.
    https://forum.efilive.com/showthread.php?26071-Known-issues-with-the-October-2015-Public-Pre-Release
    Thanks Chuck for helping solve the problem.
    Jul 2003
    what a great update!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Mar 2015
    i know this is off subject but ive been trying to find out if it is possible to change the display lettering like in your profile pic lol is it super top secret or can you help me out @GMPX
  1. Known issues with the October 2015 Public Pre-Release
    Last Post: November 14th, 2015, 10:09 PM
  2. Aug 13, 2015: EFILive Public Pre-Release
    Last Post: August 27th, 2015, 10:14 AM
  3. Aug 07, 2015: EFILive Public Pre-Release
    Last Post: August 12th, 2015, 12:46 PM
  4. July 08, 2015: EFILive Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
  5. June 02, 2015: EFILive Public Pre-Release
    Last Post: July 8th, 2015, 05:07 PM
