Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Tow Tune
    Sep 2015
    Default Tow Tune
    Tune ran fine and added a little bit more power over stock. Will some one view it and possibly give a little advise.
    Sep 2015
    Just want to know if I on the right track
    Jan 2011
    For me I think a good tow tune is just turning off all the limiters and maybe a little bit of added fuel at 60mm and above. I like to use the cummins timing calculator you can find online that josh h made. It works really well for me. Rail pressure is way to high I would just use a stock table and smooth it out a little bit. What kind of hp are you after? What other mods are done other than dpf delete?
    Sep 2015
    Nothing other than the delete and csp5 switch.I would like to get as much as my stock parts cans safely provide.I am just using my truck as a guinea pis basically to learn the ins and outs of tuning.
    Jan 2011
    Id be willing to share a tow tune with you tomorrow that ive had good luck with. Dont have my lap top with me tonight.
    Sep 2015
    Ok that would be great thank you.
    Jan 2011
    No problem. I remember when I first started tuning all i wanted was a little help here and there. But it was hard to get sometimes.
    Jan 2011
    Give me your email address and ill send you a file
    Sep 2015
    Quote Originally Posted by johnj View Post
    Jumpman23302@gmail.com
    Apr 2014
    I was wondering on the same for the towing part of the tune. did u adjust the vgt turbo any?
  1. Need 04.5' LLY Tow Tune ASAP PLEASE!
    By RAZRS EDGE in forum Diesel
    Last Post: September 30th, 2012, 03:54 AM
  2. LLY tow and millage tune
    By Hoytmax Diesel in forum Duramax LLY
    Last Post: May 20th, 2012, 02:51 AM
  3. MPG Tow Tune
    By amhobby in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:42 PM
  4. Tow tune throwing s P0401 and P0101?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 03:57 AM
  5. Stock 07.5 Lmm Tow Tune
    By newguy2diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 29th, 2007, 10:26 AM
