Results 1 to 8 of 8
Thread: SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    Oct 2003
    Default SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    http://www.plxdevices.com/Wideband-O...7346002719.htm
    Anyone have experience with this Wideband Kit. I used to have PLX Devises Wideband years ago and am looking to get another kit. But, I want to make sure there are no glitches with EFILive.
    Thanks!
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Hmmm, it has a "digital ouput"... if it's the same as the PLX serial comms stream, then V2 should be able to read it.
    Do you have a user manual pdf for it that you can post here...?
    Oct 2003
    I wanted to ask about it before I purchased since I want good integration with my V2., so I don't have a manual.
    But, here are some specs:
    Technology: PLX Critical Response Technology, Fast Response PID
    Accuracy: < 0.1AFR (Gasoline) Wideband, < 0.2AFR (Gasoline) Narrowband
    Measurement Range: 10-20 AFR (Gasoline), 0.68 - 1.36 lambda (Gasoline), 0 - 100 O2 Sensor Health, 0 - 1000 mS Reaction Time, 9 - 20 Volts
    Analog Outputs: Wideband Linear 0-5V, Narrowband 0-1V (Driving Current 20mA)
    Operating Voltage: 9V-20V
    Sensor: One Bosch LSU 4.9
    [img]http://www.plxdevices.com/v/vspfiles...bda_Analog.png[/img]
    [img]http://www.plxdevices.com/v/vspfiles...Gas_Analog.png[/img]
    There's quite a bit of info at the specs and Extended Info tabs on the product page:
    Oct 2003
    It says it has the correct Analog Output voltages from what I can tell, so I guess I will get that one.
    Oct 2003
Name:	PLX Devices SM-AFR DM-6 WB Gauge Combo kit.jpg
    Quote Originally Posted by Black LS1 T/A View Post
    Yeah, the analog output looks just like PLX (AFR = 2*V + 10).
    It looks like a PLX that supports LSU4.9...
    it looks like it supports serial comms output (which means V2 can read Lambda/AFR from it using serial comms).
    That's a really good price, not to mention it is a combo.
    Oct 2003
    Thanks for the feedkback!
    Jul 2007
    I have a couple of PLX gauges including the DM-6. The OLED screens are great at night, but aren't visible in sunlight. They look nice overall, but mine have been anything but reliable. They turn on when they feel like it. As a result, I can't really rely on them for tuning and will be replacing them with AEM gauges.
    I already have AEM gauges in two other cars and their WBO2 sensors have been nothing but reliable. I also have a NGK AFX in my 9-7X with a Speedhut gauge. It has not just been reliable, but also very accurate.
    Tim
  1. An AFR Gauge is a pretty good E10+ fuel sensor
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2009, 07:16 PM
  2. Good afr?
    By Powerhouse in forum Gen III V8 Specific
    Last Post: July 28th, 2007, 02:09 PM
  3. Autometer AFR Gauge & EFILive
    Last Post: April 18th, 2007, 03:55 AM
  4. At idle OL AFR good, CL 16 AFR
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 11:40 AM
Tags for this Thread
