Results 1 to 10 of 14
Thread: Switch throttle bodies from a sliver blade to gold back to sliver!
    Jul 2009
    Cool Switch throttle bodies from a sliver blade to gold back to sliver!
    YO guys. I have a '08 C6Z that I need help with switch back to a sliver blade throttle body (car was tuned with a gold blade). What do you have to do? I'm about to be on my 3rd different tuner and I've have enough of dealing with other dudes and its time for me to start leaning this.
    So any help would be appreciated.
    Jul 2009
    Darn...tough crowd LOL. Ok so I went to the table b1650 and change the number to 4725. Is there anything else you have to change to go back to a sliver blade throttle body? During WOT car will go into REP and most of the time its a P1516 but sometimes I will get P2119 check engine light.
    From what I've found on here and reading Greg Banish book one of two things...MAF needs to be scaled down or its in the throttle body setting need to be adjusted. I don't think its a MAF problem.
    What tables do I need to look at for the MAF and throttle body?
    Any help to point me in the right direction will be appreciated!
    Post your tune file, maybe someone who knows this will help.
    Jul 2009
    C6ZTUNE1.ctzC6ZTUNE1.ctz
    Here's the tune ladies and gents!
    Jul 2009
    bump
    Ok it appears that the throttle body setting are back to normal ( I guess from what I can tell).
    So now it seems that the MAF needs to be scaled down from what I've been reading.
    Is B1097 & B1098 what I need to scale down?
    I'll get some logs tomorrow.
    Senior Member auspeed's Avatar
    Jul 2010
    Did you end up solving this one?
    Jul 2009
    Quote Originally Posted by auspeed View Post
    Not with efi live. try doing a idle relearn. HPT came out with a deal to prevent this from happening and has stopped my issue.
    Jul 2010
    Whats involved with this process?
    Jul 2009
    The ECM see what the TB% used to be and when you swap it out or clean it there's a new %(an error from what it used to seeing) it sees and freaks out (has to do with carbon build up). its in in the scan. v7.5>dvt>ecm setup.
    Are you saying to do an Idle Relearn via V7 scantool DVT...?
  1. LS1b 12606807 OS- what maps can limit throttle blade position
    By Jetmech442 in forum Gen III V8 Specific
    Last Post: August 1st, 2014, 10:32 AM
  2. Adapter for using larger throttle bodies with DBW?
    By turbo_bu in forum Gen IV V8 Specific
    Last Post: April 9th, 2013, 05:01 AM
  3. DBW is closing the Blade under hard throttle, HELP!!!
    By JS1965 in forum Gen IV V8 Specific
    Last Post: November 20th, 2012, 03:15 AM
  4. What tables directly effect the throttle blade?
    By PRAY in forum Gen III V8 Specific
    Last Post: October 31st, 2008, 10:25 AM
  5. Throttle cracker/follower, Y bodies
    By edcmat-l1 in forum Gen III V8 Specific
    Last Post: October 5th, 2008, 09:16 PM
