Results 1 to 3 of 3
Thread: Wideband won't read pass through scanning
    Junior Member gotabav's Avatar
    Jul 2007
    Default Wideband won't read pass through scanning
    I'm having an issue logging wideband data. My previous computer and wideband both died and I've replaced them but am having no luck. I'll quit whining now....
    Here is the set up
    AEM 30-4110 gauge controller hooked to serial output directly to V2. I can read the WB on the LCD read out without any issues and it is spot on with the gauge. Attached is a short scan that I did about and hour ago just to have something to post.
    I imagine that I don't have the correct PIDs selected, but don't know for sure.
    Any help from the experts would be greatly appreciated.
    Just in case it matters, the vehicle is a 2002 Blazer with an L33 swap, 243 heads, LS6 cam and intake, stock Blazer 0411 PCM
    Thanks in advance.
    2005 Cadillac CTS-V- Forged 383, twin Turbonetics 60-1 hair dryers
    2003 GMC Envoy 5.3-(aka family truckster) bolt ons and tuned
    1999 Chevy S-10-The gutless wonder work truck
    Quote Originally Posted by gotabav View Post
    Here is the set up
    Thanks in advance.
    Please upgrade to the latest pre-release available here: https://forum.efilive.com/showthread...ic-Pre-Release
    After installing both V7.5 and V8, run the V8 scan and tune software and click on the [Check Firmware] button to ensure the firmware and config files on your FlashScan device are up to date.
    Jul 2007
    That did the trick! Worked like a champ.
    Thanks Paul
  1. wideband won't read on laptop
    By Spike669 in forum FlashScan V2
    Last Post: July 12th, 2015, 02:09 PM
  2. V2 won't read
    By rulonjj in forum FlashScan V2
    Last Post: January 3rd, 2013, 03:04 PM
  3. Pass through 5 speed Alli scanning issue
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: March 13th, 2009, 09:10 AM
  4. Can't read above 105kpa whilst scanning etc
    By ls1vt209 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 30th, 2008, 09:49 PM
  5. Scanner won't do live scanning
    By rzuff in forum General
    Last Post: July 23rd, 2007, 05:34 PM
