Results 1 to 2 of 2
Thread: changing vin on lmm to my suburban vin. is this doable?
    Mar 2007
    Default changing vin on lmm to my suburban vin. is this doable?
    So as I get closer to doing my next diesel burb swap 07 gmt 900 burb wit 07 lmm gmt 900. Im told buy a source with all factory flash equipment we might try changing the lmm ecm vin to the burb vin to make everyone in the truck happy. We dont know yet if this is possible. I want to keep my remote start and he feels we dont need vats turned off then. Whats it going to take for my remote start to continue workin?
    Edit: kept searching and it would seem put any vin I want into just about ant controller efi works on. If im wrong please correct me.
    1972 Chevy Blazer, Twin Turbo Duramax 6.6
    69 Maro TT 427 LSX, Wayne due Vett frnt sub,
    Lateral Dynamics 3 link rear, D 60,
    T56, 18X10' 18X12 Boze Forged Speedsters,
    13" wilwood 6 pot fronts 13" wilwood 4 pot rears,
    (all Still under construction)
    Mar 2009
    VATS MUST be turned off. Eric tried this every way you could think of, and finally came to the conclusion it must be turned off. It has to do with how the VATS signal is sent to the diesel ECM VS the gasser ECM. The BCM will not send the OK to start signal to the diesel ECM is the conclusion he came to, it just isn't capable of it. It is one of the differences between the GMT-900 SUV, and pickup platforms.
  1. Changing the VIN Number
    By Behold in forum General
    Last Post: January 9th, 2016, 08:48 AM
  2. vin changing- csp
    By johhnyfoxtrot in forum Cummins 5.9L
    Last Post: August 15th, 2013, 04:35 PM
  3. Changing VIN
    By derekf in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2005, 12:04 AM
  4. Vin Changing in Flashscan
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2005, 02:36 AM
