Results 1 to 3 of 3
Thread: speed vs, rpm?
    Junior Member ytry's Avatar
    Apr 2006
    Default speed vs, rpm?
    Hey guys I was hoping you could clear something up for me. i done a search and it doesn't really explain very well. If I put the vss lower and the rpm where i want it to shift, will it use both vss and rpm at this point? or will it shift at the rpm after the vss is reached? I don't want to shift to early with vss but if I had the vss set to say 35 and the rpm at 6100 will it go to 6100 before it shifts? or will it shift at 35 no matter where the rpm is.. silly q, but will help me out a lot.. Thanks for any input
    1999 Pontiac Trans-am: LS2 402, Free mods,Line lock, Nittos,Auburn 3.73's,EFI live tune, slp lid, All 3" exhaust with Magnaflow,
    The shift occurs after both conditions are met;
    so after the first condition is met, nothing happens;
    then after the second condition is met, the shift occurs;
    Notice I used the word after, meaning that the shift may occur a few hundred RPM's later, so you have to fine tune it.
    Apr 2006
    ok thanks very much.
  1. 5 speed BBL
    By Big Mike in forum Allison 5 & 6 Speed
    Last Post: April 27th, 2009, 03:49 PM
  2. 6 speed PID's
    By rcr1978 in forum Allison 5 & 6 Speed
    Last Post: August 16th, 2008, 02:32 PM
  3. Speed Cal Questions
    By arubenstein in forum E37, E38 & E67 PFI ECM's
    Last Post: July 12th, 2008, 10:05 AM
  4. 06 LLY with six speed ??
    By weazel132 in forum Duramax LLY
    Last Post: October 27th, 2006, 09:39 PM
