While I'm under the truck searching for other issues, I'm going to wire up my vintage air to my a/c. Currently I use a corvette based COS5, 02020005 that was made from a corvette 12212156.
The corvette used a ground signal into red 17 for a/c request, and the camaro uses a 12v signal into red 17. I have the series II vintage air, so it is a simple compressor wire (12V) hooked to a thermostat.
I will add a relay in this compressor feed, that will use the thermostat side of the compressor wire as power and through current(85 and 30), use the a/c output on the ECM, red 43, as the ground(86), and hook the compressor side of the wire back to 87 to receive. I will also hook the status wire from the ECM, red 18, with post 87 on the relay for an accurate status. This will work well, but how to tell ECU I am ready for a/c?
I'd like to wire the thermostat side of the compressor wire (12v when vintage air wants compressor) to the a/c request pin. To do this I would need a camaro segment and maybe a different ecu. I don't have an 0411, I have something like a 09354896 I think as my ecu came from a 99 or early 2000.
Either way- end question is....what segment contains the a/c info that would allow a 12v request instead of a ground request? I assume it would be system, but I want to make sure. Not sure if I would have an ill effects by swapping this segment??
I did spell out everything I know so far for future searchers. I will post what works once I get there.
Thanks!
