ETC parameters ony appear when you have your FS Tool plugged in to your computer(not PCM)....
RetroAus,Originally Posted by RetroAus
That's correct, and their icons appear in red, and it has to be a Commercial Licence FS.
And welcome to the forum.
Joe
Ditto and a bump^^^.Originally Posted by joecar
joel
Sorry for the dumb question. Where can I download COS 05.
2002 GMC Sierra ECSB
Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
Off the efilive website in the downloads section or just click here > http://www.efilive.com/download.aspx#downloads3Originally Posted by jamesbond2509
Chassis by Holden
Engine by Chev
PCM modified by Flashscan
Cam by Comp Cams
Link is actually on page 2 of this post only (from what I've seen). I've linked you here for convenience http://forum.efilive.com/showpost.ph...5&postcount=48
Andrew
EFILive Crew
There's an update in post #114: showpost.php?p=26981&postcount=114
I plugged OS5 in today to tidy up some idle surging I was having. Worked like a charm after following the details in this thread (after I waded through all the pages). No more idle issues
