At idle my LTFTs stay at +25. What would be my first step to bring these down to zero? Multiply the affected VE cells by a percentage greater than 100 and go from there?
RPM is set at 900 and MAP reading is 14.8 inHG.
My delemma exactly<
My idea is to knock it back in rage with IFR but let's see what the "smart guys" say?
I put mine out by loading +25% onto the IFR going from 28# to SVO 30s. This what I had calculated as the right move anyway.
PowrMax Performance
100 mm PowrMAF
usually +25 is indicative of an exhaust leak on that bank. If both banks then check for any intake leaks behind the MAF
I'm pretty sure I don't have any leaks...I think it's a result of my cam. My left and right bank follow each other pretty close.Originally Posted by Dirk Diggler
This seems to be the norm with the Halltech stinger Intake. I have a basically stock setup with the stinger and have been watching my LTFT's for a couple of months now. I have tightened, loosened, repositioned, etc. to try and get my LTFT's to come down and nothing works. I was told by Jim Hall that GM had the same results when they tested the Halltech stinger and the problem is a leak between the bridge and the smooth coupler. (Let me know if you're interested in the email that he sent me)
I found that by opening the hood, I can cut my LTFT's in half which would indicate a leak caused by the hood touching the intake when closed. Try opening the hood or closing the hood while monitoring your Long terms. I would be interested to hear your results. I'm ready toss my halltech because it won't seal and I'm just about done trying to fix it. Good luck
07 Z06 2LZ LMB: Custom Grind Cam (231/247 114+3 653/660 LSL Lobes), American Racing Headers, Ported LS7 Intake, Halltech Killer Bee.
07 GMC Sierra: Borla, S&B Cold Air
Gone but not forgotten:
EB Z06 Vette: Borla, Halltech Stinger, Long tubes
2002 WS6 Stage 2 LS6 Heads, Cam, Longtubes, Etc.
1997 Z28 Heads, Cam, Stall, Long Tubes, Etc.
1994 Z28 Boltons
[quote="Nick 02 Z06"]This seems to be the norm with the Halltech stinger Intake. I have a basically stock setup with the stinger and have been watching my LTFT's for a couple of months now. I have tightened, loosened, repositioned, etc. to try and get my LTFT's to come down and nothing works. I was told by Jim Hall that GM had the same results when they tested the Halltech stinger and the problem is a leak between the bridge and the smooth coupler. (Let me know if you're interested in the email that he sent me)
I found that by opening the hood, I can cut my LTFT's in half which would indicate a leak caused by the hood touching the intake when closed. Try opening the hood or closing the hood while monitoring your Long terms. I would be interested to hear your results. I'm ready toss my halltech because it won't seal and I'm just about done trying to fix it. Good luck[/quote
Hmmm, I have to force my hood down.
PowrMax Performance
100 mm PowrMAF
When you install a cam with a healthy amount of duration, the O2 sensors will see a somewhat erroneous oxygen level because so much of the intake mixture passes right through the combustion chambers and out the exhaust system. When I recalibrate the old mass air systems (1986-89 TPI engines) I found that I always had to bump the injector flow rate by 1.5 to 2 pounds-- that is, if 22 pound injectors were installed, I set the injector constant to 24 pounds. The ECM would then determine that a shorter pulse width was required (because of the "larger injectors". That would get the fuel trims back in range. There's no VE table in these systems, so injector flow rate is the only means available to alter fuel flow. In my opinion, altering injector flow rate should be the first step with an LS1/LS6 system. Then use the VE table just to fine tune. It's really pretty easy with the LS1/LS6 system because you can tune IFR according to manifold pressure.
Nick, interesting that you mentioned that. I had the Halltech installed before the cam install and my LTFTs were all over the place, allthough not quite as lean. I've read this before on one of the other forums.Originally Posted by Nick 02 Z06
I'll take your advice and try monitoring with hood up. I might also try running the stock bridge. I'll keep you posted.
I'll give that a try. Thanks!Originally Posted by dfe1
Just curious, but have you altered any of the typical idle tuning tables? IAC, Idle Airflow, Idle Airflow Parked, Throttle Cracker, etc... Ported TB?
It may just be me, but the more I've had to raise those IAC and idle values, the leaner my idle LTrim values have become at idle / low rpm.
Richard -
2008 Trailblazer SS - TVS1900
