Sorry for the laundry list of PIDs that are in this log but i thought it might have been transmission related and wanted to get the big picture but after watching the fuel trims i believe this is fuel pump related. Started a couple days ago and was intermittent but it lugs down when stepping on the skinny pedal. After looking at this log you can see that the LTFT goes to 25% at partial throttle when trying to accelerate. I can ease it up to the higher RPMs and it runs fine but i think the pump may not be keeping up with the volume needed when accelerating fairly aggressively. It does seem to be more pronounced when the truck is warm but the pump would be constantly running then too and warm up. I am going to mess with the PE tables a little and see if that magnifies the issue but will also be getting a FP gauge to check for sure
wtf.efi
