Results 1 to 7 of 7
Thread: Error $0333 when flashing tune on V2 out of no where...Help
    Jan 2013
    Default Error $0333 when flashing tune on V2 out of no where...Help
    All of a sudden I cant flash or read tunes on my V2 without getting the $0333 code.
    What would cause this all of a sudden? How do I fix it?
    The only thing I did different was open the original file from my PCM and save it as an up to date file so I could full flash it in, then cal flash the most recent update into place so I could get the file size back down along with updating the tune.
    I have noticed that no matter what I do I can't update the firmware on the V2 to the newest *.*.91 I think, mine ends in 82 but using V8 it says that is up to date even after downloading the most recent everything else.
    Jeremy
    PS: Tried to upload trace files ending in htx, but said invalid file extension. How do I upload a trace file then?
    Hi Jeremy,
    Directly download and install V7 and V8 from here: Sep-2015-EFILive-Public-Pre-Release
    ( i.e. do a fresh install of the new V7/V8 build rather than an update )
    and then start V8 S&T and click Check Firmware.
    More info, see post #1 here: Setting-up-a-FSV2-from-scratch
    Jan 2013
    Hi Jeremy,
    Well I did everything posted and got the firmware to update to its latest version. But I'm still having the $0333 error and cant do any reading or flashing.
    One odd thing I've noticed that may or may not have to do with any of this, is that since I reinstalled everything if I have the EFI Explorer open, or V8 Scan and Tune open, and open V7.5 Tuning Software it opens in Demo mode.
    I realize it says to close the explorer when the demo mode starts, but this never used to happen to me.
    Jeremy
    Jan 2013
    Any ideas?
    Jan 2014
    I just recently updated and had all sorts of problems.
    Try updating all you software, then reformatting the v2. I had to completely reformat the memory for it to work again without tossing error codes.
    Jul 2015
    Also check the alt keys box when trying it. I had the same issue a while back and that was the culprit. for some reason i always have to use the alt keys now
    I made a sticky in the V2 subforum especially for Error $0333... please see this: Error-$0333
  1. error $0333 No Description available
    By JUSTASBC in forum FlashScan V2
    Last Post: June 8th, 2015, 05:10 AM
  2. $0333 error
    By JLawson in forum Duramax LB7
    Last Post: June 21st, 2013, 04:31 AM
  3. $0333 error...
    By Danny Richie in forum AutoCal
    Last Post: May 24th, 2013, 09:02 AM
  4. $0333 Error
    By Dmaxink in forum AutoCal
    Last Post: August 8th, 2012, 01:24 PM
  5. Flashing Error
    By TexasCummins in forum Cummins 5.9L
    Last Post: February 10th, 2012, 09:37 AM
