Results 1 to 6 of 6
Thread: Updated V2 firmware now error 0333
    Jan 2013
    Default Updated V2 firmware now error 0333
    I updated to the latest firmware:
    boot block 2.07.07 feb 7 2014
    firmware 2.07.82 apr 10 2015
    efilive is v8.2.2.276
    the firmware update window says that everything is OK
    and now i cant bbx read or write to my pcm. it is a ls1b that i have written to many many times,
    it now returns a $0333 error
    i have not locked anything
    i checked and the tune is not locked
    I can read and write using a laptop and passthrough with the two extra boxes checked, "assume faulty lock" and "use alt keys"
    i have re-saved the full config to the v2, i made sure ls1b is checked for supported modules
    My laptop is a pos and the battery only lasts a few minutes, i really need this standalone feature. i havent used a laptop in my truck in years
    is there a fix for this?
    Jan 2013
    I just updated everything to the latest pre-release (https://forum.efilive.com/showthread...ic-Pre-Release) and tried reading the pcm and got the same 0333 error.
    Did you flash firmware 2.07.91 into your V2...?
    See post #1 here: Setting-up-a-FSV2-from-scratch
    Jan 2013
    yes that is the firmware that i currently have installed in my v2
    I followed the steps in the first post, then went to my truck and tried to read the cal then write the cal and both processes failed with the same error.
    The fix is described here:
    https://forum.efilive.com/showthread...l=1#post222867
    Jan 2013
    that fixed it, thank you!
  1. error $0333 No Description available
    By JUSTASBC in forum FlashScan V2
    Last Post: June 8th, 2015, 05:10 AM
  2. new updated autocal getting $0333 code
    By mpelt in forum AutoCal
    Last Post: March 24th, 2015, 03:13 PM
  3. $0333 error
    By JLawson in forum Duramax LB7
    Last Post: June 21st, 2013, 04:31 AM
  4. $0333 error...
    By Danny Richie in forum AutoCal
    Last Post: May 24th, 2013, 09:02 AM
  5. $0333 Error
    By Dmaxink in forum AutoCal
    Last Post: August 8th, 2012, 01:24 PM
