Results 1 to 3 of 3
Thread: 6 speed not updating current gear fast enough
    Apr 2012
    Default 6 speed not updating current gear fast enough
    After my track outing today, I have found that the current gear is not updating quick enough after a shift. It is making rpms go north of 4200rpm because it will not command the next gear change until the current gear is updated. I am going to include a tune file and a snapshot of the log. Tune is basically stock with WOT shift points set way low trying to get a gear change. Anybody run across this before?
    Lifetime Member LB72004's Avatar
    Dec 2011
    I had mine act weard like that then I dropped the MPH and RPM down low too. Shifted fine when I used the tap shifter and changed gears at about 2500-3000 RPMs.
    Seemed to me that trying to get it to shift below 2000 or so RPMs at WOT made it refuse to shift.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Dec 2011
  1. Car dies after fast shift to third gear
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: April 16th, 2011, 11:03 AM
  2. Where is Current Software?
    By GAMEOVER in forum General
    Last Post: October 20th, 2010, 10:08 AM
  3. Current Gear and Oil Temp
    By kwhiteside in forum FlashScan V2 BB Logging
    Last Post: June 21st, 2009, 08:28 AM
  4. what table controls start up decay speed? "how fast it decays out"
    Last Post: March 20th, 2009, 12:10 AM
  5. V2 current usage?
    By Cougar281 in forum FlashScan V2
    Last Post: February 19th, 2008, 11:05 AM
