Results 1 to 10 of 10
Thread: Cal_Link / RR Prob
    Dec 2014
    Default Cal_Link / RR Prob
    Quick question for you guys. I have had my RR for a while and usually I just use a single wideband to tune. Well, working on a TT 5.3 and the owner installed 2 widebands. I noticed that the first wide band was acting flaky so I wanted to switch to the second. No matter what I do I can not get the second channel to work with the RR. It works fine in the scanner and I can log all day with it, I was logging both channels the entire time.
    [LS1]
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
    B0101.RRR=CALC.BEN_LC11,CALC.BEN_LC12
    Thats the setup I have right now. WHen I would try and use CALC.BEN_LC12 I could not get the RR to work with it. I even tried this.
    [LS1]
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
    B0101.RRR=CALC.BEN_LC12
    Still nothing. I had to physically move the #2 WB to the #1 input to use it with the RR.
    Am I missing something here?
    Sanity check: on scantool PIDs tab, did you deselect CALC.BEN_LC11 and select CALC.BEN.LC12...?
    Dec 2014
    Many times. LOL
    I have been logging both channels the whole time. I just can not get the RR to work with CALC.BEN_LC12
    Dec 2014
    I have been through everything. I can not find where anything would be off. So now when I need to switch I just change the AD assignment in the sae_generic.txt.
    [LS1]
    ;Main VE Table
    B0101.ROW=SAE.RPM
    B0101.COL=SAE.MAP
    And, you did this ^ in the file LS1_Link.ini, correct...?
    Dec 2014
    You are the man.... I knew there had to be a second file. CALC.BENLC12 - Is what was there. Now its corrected to CALC.BEN_LC12.
    Thanks!!!!
    Dec 2014
    So with that said. There is a typo in the cal_link and LS1_Link
    After investigating, it appears the typo exists multiple times in most *_Link.ini files. I'll get it fixed for the next update.
    Thanks for tracking it down.
    Dec 2014
    Awesome!! Thanks.
    Nov 2005
    Paul, just wondering if you got my PM that I sent a couple weeks ago?
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
  1. why does this happen alot? -log reading prob
    By whackem04 in forum General
    Last Post: December 29th, 2009, 03:24 PM
  2. Cal_Link
    By Big D in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: November 28th, 2009, 10:47 PM
  3. Upto date Cal_link file
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 24th, 2008, 05:33 PM
  4. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
