Results 1 to 1 of 1
Thread: Error $0333
    Default Error $0333
    Please see post #6 here: Sep-2015-EFILive-Public-Pre-Release
    Sounds like the LS1B controller has a damaged seed/key combo. When managing remote customers with an LS1 with a faulty seed/key, you can bypass the faulty seed/key combo when flashing the controller using BBX by setting the [Remote Control] options as shown below. Those settings are stored in the file and are only used for that single file. Because those settings are stored in a tune file they can't be used for reading a controller.
    If you want to fix the seed/key (and I recommend that you do), then you need to use V8 pass-thru reading/flashing:
    1. Read the tune from the PCM (with the "Try Alt Keys" and Assume Lock May be Faulty" options checked) or open a file that matches the OS in your PCM.
    2. "Save As..." the file with the name "Unlock.ctz".
    3. Check the "AutoLock" option on the [Security Restrictions] tab page.
    4. "Save As..." the file with the name "Lock". You muct have your FlashScan connected when saving any file with any security restriction active.
    5. Cal-flash the Lock.ctz file (with the "Try Alt Keys" and Assume Lock May Be Faulty" options checked). That will set the seed/key to a custom seed/key combo.
    6. Cal-flash the Unlock.ctz file (with the "Try Alt Keys" and Assume Lock May Be Faulty" options un-checked). That will reset the seed/key to a stock seed/key combo.
  1. Updated V2 firmware now error 0333
    By TrendSetter in forum FlashScan V2
    Last Post: October 5th, 2015, 12:01 PM
  2. error $0333 No Description available
    By JUSTASBC in forum FlashScan V2
    Last Post: June 8th, 2015, 05:10 AM
  3. $0333 error
    By JLawson in forum Duramax LB7
    Last Post: June 21st, 2013, 04:31 AM
  4. $0333 error...
    By Danny Richie in forum AutoCal
    Last Post: May 24th, 2013, 09:02 AM
  5. $0333 Error
    By Dmaxink in forum AutoCal
    Last Post: August 8th, 2012, 01:24 PM
