Results 1 to 5 of 5
Thread: lq4 and 411 pcm swap in 98 suburban
    Jun 2009
    Default lq4 and 411 pcm swap in 98 suburban
    Hi everyone , havent been here in a bit . I finished my second swap of this sort , lq4 in a 98 suburban with a 411 pcm. Lextech was great when i did my first one, lots of help. Everything is great and it runs fine but i am just wondering about a U1255 dtc which is lose of communication between moduals i am getting , i looked in my tune and the procession and mil is turned off for that so i imagine the BCM is looking for the old PCM and is setting that code, is it possible that the BCM could set this code . Thank you . eric
    Jun 2009
    Anybody know about this. It is probably not important , it may not come back once i clear it , just not at my friends to do so till next week. eric
    Looks like one or more of the other modules is not able to talk with the PCM... like you said, probably the BCM.
    Jun 2009
    Thanks Joe, yes i guess that is it. I did not know the BCM could set a code, it is not the pcm as i checked and the processing for that u1255 is off. I will look into this next week when i see my friend to finish a couple things up on the suburban.
    Jun 2009
    I know i could see if the 98 suburban uses PWM for communication between moduals or the newer class 2 , i am sure it is PWM. I could match that up but we are not even using the vats security as my friend has an aftermarket alarm system . I am sure that it would work though if i set the PCM to the same communication format as the BCM and did a vats relearn.
  1. LQ4 hotcam Third Gen Swap
    By jbettcher in forum Gen III V8 Specific
    Last Post: May 19th, 2013, 06:49 AM
  2. need info on 411 pcm for 6.0l swap into 98 silverado
    By Eric in forum Gen III V8 Specific
    Last Post: January 28th, 2013, 05:39 AM
  3. 411 swap did not go well
    By FeetDry in forum Gen III V8 Specific
    Last Post: June 9th, 2011, 04:50 AM
  4. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
  5. pcm swap any 411 will work?
    Last Post: May 25th, 2009, 11:30 PM
