I don't know if this is normal or not, but it sure is frustrating. It seems when I load a PID file, my "Maps" will change to other map configurations that I may have used in the past. Then I have to clear the map and reload the one(s) I want to work with. Is this normal? Is there a way to disable it so that the scan tool remembers the maps I'm using and doesn't clear them or switch them to another map? It's extremely frustrating. If someone can help, I'd sure appreciate it. Thanks!
Brad
