Do this:
- unplug V2 from USB and OBD2,
- while plugging V2 into USB, hold down the CTRL key on your V2, the 2 orange LEDs should start flashing (dead poll mode),
Now do this:
B If FlashScan has boot block V2.05.04, please perform these steps:
1. Program firmware V2.05.14 (unless V2.05.14 is already installed in your FlashScan). <-- see note below.
2. Program boot block V2.07.xx.
3. Program the highest version number firmware file from the folder: \Program Files\EFILive\V8\Firmware.
note: to do step use EFILive Explorer, goto Firmware tab and program in the firmware.
Now, after you've done that, your V2 should boot up ok, and then now do this:
- download V7/V8 software from here: Sep-2015-EFILive-Public-Pre-Release
- install V7 and V8,
- using EFILive Explorer program the new bootblock and firmware into your V2.
