Results 1 to 5 of 5
Thread: open loop tune help
    Aug 2015
    Default open loop tune help
    finally got my my friends Camaro with 414 lq4 engine idleing and driving good with some help of another tuner and since then its been running rich over the entire range and I have been trying to take fuel out of the entire ve table to get into the ballpark of my commanded afr and it doesn't seem to change the readings as much as I have been taking it out of the ve table. I am beginning to think there is something else influencing the fueling. can someone make sure I changed this to full open loop and if not what do I need to change to take full control of the ve table. No maf by the way.
    eps 414ci trans shift change_0001.ctz
    If you're trying to tune this in open loop, then you're not quite in open loop...
    B3647 contains cells which are stoich (EQR 1)... in OL the COS will do STFT trimming on these cells...
    this is known as Semi-Open Loop (because it's not quite open loop);
    to avoid this, set the stoich cells in B3647 to say EQR 0.99 or EQR 1.02.
    Also note:
    in the presence of a MAF DTC (because you want SD), the COS still allows the HO/LO adaptive spark to function.
    Aug 2015
    Also note:
    So if I change all afr cells to something other that 14.63 to say 14.2 then it will affective make it open loop?
    Quote Originally Posted by Jacob lowe View Post
    Yes.
  1. Replies: 1
    Last Post: April 11th, 2013, 04:28 PM
  2. Need help for a 5.3 twin turbo/E85 SD Open Loop Tune
    By Sinister in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2012, 02:36 AM
  3. Replies: 3
    Last Post: January 10th, 2012, 03:15 PM
  4. Open loop SD Tune Emissions Help.
    By Janke in forum Gen III V8 Specific
    Last Post: February 15th, 2011, 04:40 PM
  5. How do you tune in open loop???
    By WiseGuyZ06 in forum Gen III V8 Specific
    Last Post: May 20th, 2007, 07:25 PM
