Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 114
Thread: Read HPTuners Tune with EFILive. 2 Bar
  1. #101
    Comments on 20151126aSDAutoVE.ctz:
    A0001, A0002: set these to 100%.
    A0012, A0013: set these to 511 mph (i.e. max-1).
    B3613: set this to 105 kPa.
    B3647: set upper 3 columns to EQR 1.185.
    B3618: set this to EQR 1.265.
    B3616: set 3200, 3600, 4000 to 34%.
    B3603, B3659: set these to EQR 1.265.
    B4105: set all cells to 450 mV.
    B5913, B5914: these may have too much advance in the high load columns, possibly need to subtract 6 degrees.
  2. #102
    You have a 4L60E with a 2.84/1.57 gearset...?
  3. #103
    VSS vs TP shift tables are not suited to street/daily driver.
    D0701, D0702, D0703: can increase pressure, say +10%.
  4. #104
    Oct 2003
    Yes... 6-pinion planetary. I'll never go back.
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
  5. #105
    Quote Originally Posted by Black LS1 T/A View Post
    Yeah, I like that gearset, makes the 4L60E ratios closer, allows you to use less stall.
  6. #106
    Also: keep your wideband-to-V2 analog connection, and see if you can get the serial comms connection going also.
  7. #107
    Oct 2003
    Mine said max of 824, so I set it to 823 (-1) if you still intend I set it to 511, let me know..
    Do you mean "upper three rows"?
    How many columns are you calling "High load"? Which ones?
  8. #108
    Oct 2003
    For now, I set 1.20 coum to 12, and added 1 degree per column until it matched what I already have (at column .96/1.00)
  9. #109
    Oct 2003
    It cut off if decreased below 1500 RPMS. I waited until it warmed up, and when I manage to baby the throttle downt o 900, it would stay there. But, if I increased throttle back up to 1500, it stalled out and cut off.
    Adjusted wrong table. RE-flashed. After warming about 3 or 4 minutes (weather in the upper 50's right now) it wouldn't idle off throttle. But I will drive out with that tune and see what happens rolling. I'll post result at work.
  10. #110
    Oct 2003
    Also, keep in mind I'm in AutoVE Tune mode right now ... Forced Octane Scaler was turned off and things like TOS VE Table are disabled as well.
  1. efilive or hptuners?
    By dian in forum Gen III V8 Specific
    Last Post: December 10th, 2014, 01:25 AM
  2. Replies: 8
    Last Post: June 10th, 2013, 06:57 PM
  3. efilive v2 vs hptuners
    By mellor in forum FlashScan V2
    Last Post: November 8th, 2010, 08:46 AM
  4. I somebody emails me a HPTUNERS file, can I load it into a car with my EFILIVE??
    Last Post: March 24th, 2010, 11:01 AM
  5. Flashscan vs HPTuners? Upgrade from EFILive
    By Iv_z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2004, 10:29 PM
