Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: help! E67 enabled flex....
    Unfortunately it is not that simple, with differences in the many other modules between vehicles (eg, Corvette to Commodore) all the modules need to be talking the same language, each ECM program is configured specifically for that model vehicle and generally won't work when swapped in to another.
    I don't think GM ever offered E85 from factory on any of the supercharged V8 engines using the E67, only some of the older V6's had it.
    Feb 2005
    So by the sound of it, it's either E85 or 98 fuel?
    More like 98 or 95
    Feb 2008
    almost all e67 have flex fuel tables 09-15 ctsv uses the e67 and has flex fuel tables , same goes for the corvettes
    Junior Member clubby5000i's Avatar
    Jul 2007
    Quote Originally Posted by AGRO View Post
    Hi all,
    I enabled B0178, and the mil to suite, wired in the flex sensor, car wont start!
    when I disable B0178 starts and runs perfect.
    The car in question is a 2015 HSV GTS LSA OS:12656942.
    Hi there mate, did you ever find the solution to this? Got an LSA with exactly the same issue. Enable the B0178 it will not start the car.
  1. Flex Fuel E67 Pin for frequency input?
    By 1INSANEV in forum General (Petrol, Gas, Ethanol)
    Last Post: October 29th, 2017, 11:06 AM
  2. Can VVT be enabled on a non VVT tune? E67 2007 CTSV
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: April 2nd, 2017, 05:57 PM
  3. CSP5 {A9643} Enabled or Disabled?
    By xploitdiesel in forum Cummins 5.9L
    Last Post: September 25th, 2013, 06:16 AM
  4. GEN IV swap AFM is not enabled
    By harascho in forum Gen IV V8 Specific
    Last Post: January 29th, 2009, 07:01 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
