Results 1 to 2 of 2
Thread: Having a issue with tuning
    Junior Member 05chevy's Avatar
    Oct 2011
    Default Having a issue with tuning
    Lbz 60% over and built trans. Truck idles fine in park. When. You drop into gear it will lope. Only does it in the base tune. Not in any other. Tried playing with b1021 table. And didn't help. Any suggestions? Thanks
    05 lly 11.69 @ 115mph. stock motor, s475, 40% nozzles, lbz reg
    685hp/1100ftlb
    11 Cruze 1.4L turbo
    Lifetime Member LB72004's Avatar
    Dec 2011
    your issue is likely in B0720. have you made the appropriate adjustments to compensate for the 60 over injectors?
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  1. Wierd issue after flash, airbag light on & oil reset issue
    By Tool Guy in forum Gen III V8 Specific
    Last Post: October 1st, 2013, 06:55 PM
  2. Replies: 21
    Last Post: July 7th, 2013, 11:31 AM
  3. Replies: 7
    Last Post: June 1st, 2012, 04:26 PM
  4. TCC Tuning Issue
    By BlownSierra in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 21st, 2011, 01:16 PM
  5. New Issue
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 16th, 2006, 10:07 PM
