Results 1 to 10 of 10
Thread: Brake Torque Management
    Feb 2013
    Default Brake Torque Management
    E38 12607218 OS T42 Auto
    Is it able to be disabled in EFI-Live?
    If so where do I look other than B2523?
    Thanks guys..
    Not sure what vehicle you have but turning off the TCS will also disable the BTM system anyway.
    Feb 2013
    It's an Autocross car with VZ Commodore Electricals and electronics, TRAC is off but it's still doing the BTM thing.. thanks for the reply.
    Ah ok, it is probably defaulting to staying on. I think (someone might dispute this) if you are using a Ute tune then this is what happens, on the sedan tune it is ok.
    Feb 2013
    99% sure it's a Sedan tune, I'll check..
    Feb 2013
    And that .1% bit me in the arse... it's been flashed as a Cab Chassis... :(
    Can I use a Sedan VIN/File if I can find one and will it need to be licenced again?
    Quote Originally Posted by IJ. View Post
    ECM is already licensed (license attaches to ECM's serial number).
    Feb 2013
    Thanks Joe!
    Just find a sedan version with the same OS, turn off what you need for the conversion and I think you'll be fine.
    Feb 2013
    Thanks for the help!
    Just in case anyone here is interested this is the car>>
  1. Replies: 5
    Last Post: February 11th, 2014, 02:53 PM
  2. Where is the Brake Torque Management Button B9905 at??
    By mega2006 in forum Cummins 5.9L
    Last Post: December 11th, 2012, 12:21 PM
  3. Brake Torque Management Screen Shots Needed
    By LeftCoast32 in forum Gen IV V8 Specific
    Last Post: September 5th, 2011, 03:11 AM
  4. B0401/0402 Brake Torque Management (BTM)
    By TurboCamaro in forum Gen III V8 Specific
    Last Post: September 30th, 2010, 08:55 AM
  5. Brake Torque Management?
    By trudynosports in forum Gen IV V8 Specific
    Last Post: February 28th, 2007, 10:14 AM
