I think it was a text file that could be changed and when the ECM was being flashed it would display a message, someone else might recall the specifics.
on the 2003-2005 trucks that would show a text message on the cluster during reflash??
Yeah, its in the documents/efilive/v7.5/userconfiguration folder...the "messages.txt" file. The command/message string to send text to the cluster is slipped into the bootloader, and then the ECM sends the cluster text messages back to the cluster at various points during the flash.
2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison12.9s @ 108 mph
many thanks to Ross and Paul
The messages are contained in the file \My Documents\EFILive\V7.5\User Configuration\Messages.txt
Each message must be 20 characters or less
Example file:
Code:[MESSAGES] DONE = EFILive FINISHED LOCK.01 = LOCK IN PROGRESS FLASH.01 = EFILIVE FLASHSCAN FLASH.02 = FLASH IN PROGRESS FLASH.03 = www.efilive.com READ.01 = EFILIVE FLASHSCAN READ.02 = READ IN PROGRESS READ.03 = www.efilive.com
This got me for some hrs ,thinking I was crazy, doesn't help when customer has there fuel pumps wired to 12 switch full time killing the battery every time I would check
I was like hmmm even gone from old logs
See Issue #3 here: https://forum.efilive.com/showthread...ic-Pre-Release
