Results 1 to 6 of 6
Thread: $0185 Error File Folder
    Member ippielb's Avatar
    Jun 2010
    Default $0185 Error File Folder
    Went to try and log on my scan tool on my 06 duramax. Went to the LBZ and wanted to start to log, came up with a $0185 error, file folder not found. Tried to fix the problem myself, formatted the memory card, formatted the tune tool. Checked the software versions, i'm at a loss.
    2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    NADP Race Transmission & NAPC Built Transfer Case
    AFE Stg 2 Intake Snow Performance Methanol Injection
    FASS 150gph Titanium Series Pump EFI Live
    PPE Race Valve & PPE Fuel Rail Fitting
    BD Manifold 3" AFE Ceramic Downpipe 4" Straight Pipe
    Yukon Grizzly Locker Mag-Hytec Cover & Traction Bars
    Leveling kit & 33" Hankook RT03 18" XD Addict Rims
    HID's all around LED taillights and 3rd brake light
    Autometer Fuel Pressure, Boost, and Pyro Gauges
    Quote Originally Posted by ippielb View Post
    Error $0185 is file not found. Most likely the file that is not being found is the Options.txt file or some dependent file.
    You should set up the black box logging options using the V8 software's [F5: BBX] tab page, something like this:
    When you click the [Program] button the Options.txt and all required dependent files are copied to your FlashScan device.
    Did you use the format option in FlashScan to format the SD Card? If not then the required folder structure may not be present on the card - which can also cause the $0185 error.
    To format your SD Card, use FlashScan's built in option:
    F4 Options -> F2 File System ->F3: Format File Sys
    Jun 2010
    I formatted everything again, tried a different memory card and programmed the controller. Tomorrow morning i will try to log again.
    Yes sir, went onto the forums here, and searched it to double check. The instructions that are provided in the scan/tune tool were spot on.
    Jun 2010
    So, after the program of my controller, went to my truck, the LBZ/LMM wasn't programmed onto it. Weird, after i got home plugged it in, i guess i accidentally deselected them from the list. Re-programmed with the LBZ and LMM PID's. Today, went out to my truck, hooked up, went to select my LBZ, worked, i displayed the data, worked great. Then i went to log the data and it comes up $0185 error again.
    I went into my explorer program right now and the EFI Live folder is empty in my memory card. Can a guy repopulate the folders for tune and scan automatically or does he have to make the folder manually.4
    EDIT:
    When i tried to make manually it gives the $0185 error.
    EDIT AGAIN:
    Formatted the SD card once more, this time it created the folders for me.
    EDIT AGAIN:
    Glad its working for you now.
    Just for others who may have the same issue:
    If you use FlashScan's onboard option to format the SD Card then it will make the folders for you.
    If you remove the SD Card and format it using a PC (with a card reader) then it won't make the folders for you. In that case you'll need to create the folders manually as follows:
    \EFILive
    \EFILive\Scan
    \EFILive\Tune
    \EFILive\Tune\Read
  1. BBX issue ERROR $0185 file or folder not found
    By frankenstien in forum FlashScan V2 BB Logging
    Last Post: June 1st, 2015, 07:53 PM
  2. Error $0185, one fix?
    By Wolfie in forum FlashScan V2
    Last Post: August 7th, 2011, 10:11 AM
  3. Error: $0185
    By gpr in forum Gen III V8 Specific
    Last Post: September 18th, 2009, 09:39 AM
  4. error $0183 and $0185
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: May 24th, 2009, 04:39 PM
  5. $0185 error
    By hymey in forum FlashScan V2 BB Logging
    Last Post: March 24th, 2008, 12:52 AM
