Results 1 to 3 of 3
Thread: PLX WB reading 13.6-13.62 in all cells
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default PLX WB reading 13.6-13.62 in all cells
    Trying to log AFR using PLX. Regardless of cell I am in, AFR is staying between 13.6 and 13.62.
    Suggestions, please.
    Apr 2005
    Open loop or closed loop? What is the commanded AFR? Have you checked the voltage and setting of the PLX? The standard PID expects:
    0v -> 10:1 AFR
    5v -> 20:1 AFR
    (V * 2) + 10 = AFR
    So, 13.6 AFR should be ~1.8v. Check the voltage at the input to EFILive.
    Also, log all trims (LTFT and STFT). You may think you are not trimming, but may still actually be doing so.
    Sep 2003
    Issue resolved. Had it wired up wrong. Thanks
  1. How to select mutliple cells in a row to smooth?? but not all of the cells.
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2010, 03:34 PM
  2. Reset Tap Cells
    By jaydog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 23rd, 2009, 08:05 PM
  3. MAP cells all the same colour????
    Last Post: October 21st, 2008, 05:02 PM
  4. Highlighted Cells?
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2007, 02:17 PM
  5. How do we hide cells ?
    By johnv in forum General
    Last Post: September 8th, 2005, 02:20 PM
