Hi guys!
Is there any way to change remote start maximum attempts count on ecm side?
It allows only 2 starts, then declines RVS requests. This can be observed with Tech2 in Electrical/Theft Data.
We've already overcame 10 min and 2 attempts issue on BCM side and now on third and next attempts ignition turns on, SES came on for about a half second and then all goes down. BCM shows 'ECM Crank Abort - YES' in the remote start history.
I've asked my friend to try using EFILive on the vehicle and we found only 'Remote start enable' option.
It will be great if someone will try to work on this issue.
OS 12639835
Some tips
ECM limits only start attempts and stock calibrations has a limit of 2.
Engine running time is completely controlled by BCM.
