I think I may have wiped out my autocal but I still have the tunes on my computer so I reloaded them and now when I try to load it into the truck I get get a 053E code. Anyone know the solution for this?
$053E Device license number is not valid. You cannot use a tune file tagged with Auto Lock if the AutoCal device serial number is not valid.
The other possibility is the VIN number in the tunes being incorrect but if those were the same tunes that you were previously using that's not the problem.
What did you do to the AutoCal to make you think that you wiped it out?
Here's the error code doc for future reference.
http://content.efilive.com/documents...or%20Codes.pdf
2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
2017 Corvette 3LZ Z06 M7 with Z07 Package
I think I wiped out the bbx file. It was previously used on the truck but u had upgraded tune written for the truck.
