Results 1 to 10 of 13
Thread: Dsp5 flashing issue
    Jan 2015
    Default Dsp5 flashing issue
    Went to flash an 04.5 LLY last night and I got the message in the picture below. So I clicked Alt keys, assume lock may be faulty, try additional unlock strategy, and high speed I attempted to flash i[IMG][/IMG]t again with no avail. I'm hoping its an easy fix, but I'm worried the ecm is done for.
    Truck is all stock besides gauges, and a edge insite.
    All of my stuff is up to date. Any help is greatly appreciated!
    Oct 2015
    Are you flashing direct to the OBDII port (Edge Insight Unplugged not Pass Thru)?
    $0101 No data received
    CAUSE: USB cable is faulty or not connected. In rare circumstances the PC operating system or the EFILive software may be malfunctioning. In even rarer circumstances the FlashScan or AutoCal device’s USB circuitry may have been damaged. That damage occurs when the laptop is powered by a voltage inverter supplied from the vehicle’s battery. A power inverter must never be used to power the laptop while it is connected via FlashScan or AutoCal to the vehicle.
    ACTION: Check USB cables, plugs and connections. Try using a different USB port and/or different USB cable. Try rebooting the PC/laptop. Try using a self-powered USB hub between the PC/laptop and FlashScan or AutoCal. Try re-installing EFILive software which also re-installs the USB drivers.
    Jan 2015
    Flashing directly into the OBDII port. And I have never used an inverter while flashing. I will try that and see what I come up with. Truck is currently in a no crank position. Is it possible that the ecm is still good?
    Oct 2015
    ECM Is probably okay. Disconnect both batteries and wait 10~15 minutes. While waiting Charge the truck batteries but BE SURE to Disconnect the charger before proceeding to the next steps! Now, reconnect batteries and flash a Stock Tune
    Mar 2009
    Also is there an aftermarket radio in the truck? If so make sure it is REMOVED from the truck, and the door chime adapter module removed as they are KNOWN to crash the bus and cause a no data received error. Also they can sometimes pop awake during a flash, and stop the process or even worse brick an ECM.
    Jan 2015
    Quote Originally Posted by THEFERMANATOR View Post
    No none of that in the truck at all, I even pulled all the radio fuses last night. Like I said it is all stock besides a pair of Autometer gauges
    Did you try what Move'n' Up suggested? Pull the battery(s) for a minute and try again.
    Jan 2015
    That is the next step. The day job has me tied up until 6 tonight and then I'm going to try it again. Hopefully it will work this time!
    May 2008
    pull the radio fuses and amp. two 15 amps and a 30 amp, down in the lower right hand corner.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Jan 2015
    Update time.
    When I got to the truck this afternoon this is what I did.
    Opened Scan Tool and cleared all of the codes.
    Opened V8 (said a few choice profanitys) and preformed a full flash without a single hiccup!
    Truck now runs like a scalded dog. I didn't do a single thing different from the first flash attempt last night and it just worked tonight.
    Thanks for all the help guys, it is greatly appreciated!
  1. flashing issue
    By crash85 in forum Duramax LLY
    Last Post: February 28th, 2015, 09:20 AM
  2. DSP5 issue
    By Jon in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2012, 04:15 AM
  3. Replies: 6
    Last Post: January 4th, 2012, 11:46 AM
  4. BBX Full flashing a DSP5/DSP2 operating system?
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 21st, 2011, 02:22 AM
  5. 05 TCM flashing issue?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 10th, 2009, 05:00 PM
