Thread: $0322 any tips?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default $0322 any tips?
    Hey guys,
    I sent trace files to the support email, but while I await the reply:
    Anyone else had the dreaded $0322 code come up on the autocal while attempting to flash an LML?
    Had it happen once on a Cummins, did a pass through flash and it worked fine, no such luck in this case. Tried unhooking batteries, tried a stock tune with and without vin restrictions, etc. Pulled radio fuse.
    Naturally it erased just enough data that the truck won't start now and returns $0101 now continuously....
    Does it need to be reflashed by a GM Tech 2 in order to at least restore it back to original?
    Thanks for any insight.
    Peace Through Torque
    www.PunisherPerformance.com
    Quote Originally Posted by LBZoom View Post
    Did the tune attempt to flash again or no communications?
    From Autocal or as a DTC? U0101?
    Shouldn't need that, but as a last resort you could try.
    Jun 2008
    No communication after the small effort it made during one attempt, before it again gave a $0322
    $0101 no data received from autocal (was using it in pass through mode at this point)
    Alrighty
    Jun 2008
    Here's a screen shot from the most successful attempt, this is where it erased just enough....
    Dec 2013
    Any update to this? Has me worried, getting ready to tune my first LML next week...
    Since LML support came out we haven't had a lot of direct contact from people with flashing issues, so don't be too worried. With the problem truck above I've not heard anything more.
    Sometimes it is as simple as just pulling the battery for a minute and try again, the Bosch ECM's can sometimes get themselves in a knot when flashing, having said that they are for the most part pretty stable.
  1. LML ECU 0101 and 0322?
    By engr7581 in forum Duramax 2011+ LML / LGH
    Last Post: May 4th, 2015, 11:02 AM
  2. $0322 Error
    By darcy in forum Gen III V8 Specific
    Last Post: September 15th, 2014, 12:56 AM
  3. Error $0322 kodiak 4500
    By Rstowe in forum FlashScan V2
    Last Post: August 7th, 2014, 03:58 PM
  4. Getting codes $0322, $0312 Need Help!
    By toloud4u28 in forum FlashScan V2
    Last Post: October 31st, 2010, 02:46 PM
