Results 1 to 10 of 17
Thread: L96 6.0 swapped into 2009 Suburban
    May 2011
    Default L96 6.0 swapped into 2009 Suburban
    I moved this over from the V8 section as maybe nobody looks at that part of the forum.
    Hey Everybody,
    I haven't been on here for a few years but you were a great resource at the time and figured I would try here!
    I had a major oil pressure issue in my 2009 Suburban with a 5.3 and decided to swap in a 2011 L96 6.0. My tuner is not all too familiar with late model LS programs and I figured I would ask around to see if anybody may have some ideas of what is happening? Now that the weather is starting to get cold I continually have the stabilitrak come in when the engine is cold, and there are drivability issues mainly when cold as well. The truck pops up the code 0601 often as well I should note.
    Mid to high throttle there is never a problem, its the low throttle stuff that there is an issue with. For example, on the highway around 1800 rpm it will feel like the truck is "hovering" around different programs and can be choppy.
    There was an issue where it felt like the cruise control was on all the time, like a commanded airflow was too high which has been "fixed", but now that only seems to be the case when coming down into 3rd and 2nd gear towards a stop sign.
    This was tuned with HP tuners, but I have access to EFI live and pulled with that. If someone has some time to look at this, offer suggestions, etc I would be greatly appreciative.
    Note: I do not have a wideband anymore as it stayed with my last car. I am up to suggestions on an economical one to purchase so I can complete some logs.
    Thanks all!
    Josh
    BTW: A few things I saw when poking around even though I am not sure if it matters....
    1. I do not see anything about the VVT, looks like it is not even being commanded.
    2. The compression ratio is wrong, should be 9.6.
    May 2011
    No ideas? Too vague of questions? I am Looking for a place to start, but I have not received ah feedback and am frustrated to near the point of giving up and putting my old engine back in.
    Please, anybody!
    Aug 2010
    Hello Nver2loud,
    A couple of questions …
    The original 5.3L (LC9 ?) in your 2009 Suburban – was it a Flex Fuel compatible with AFM (DOD), and VVT ?
    The 2011 L96 6.0L should have VVT, but no AFM, and I don’t think these were Flex Fuel (no Flex Fuel in my area, so I don’t tend to pay much attention to this option).
    If your original 5.3L engine did not have VVT, was the engine wiring harness modified to accommodate this option ?
    Best regard,
    Taz
    May 2011
    Hi there, my original lc9 was flex fuel and afm, NO vvt. The replacement engine is Flex fuel but NOT AFM, however is equipped with VVT and I added the corresponding pins to the ecu.
    Thanks in advance!
    Josh
    O
    Quote Originally Posted by Taz View Post
    Hello Nver2loud,
    Best regard,
    Taz
    Aug 2010
    OK ... it sounds like you have the VVT wiring squared away.
    I would suggest beginning with a tune from a 2009 Suburban equipped with the LY6 6.0L engine. These used the same APP (gas pedal), throttle body, and ECM OS as your 2009 5.3L Suburban.
    The LY6 was VVT, but not Flex Fuel - so that would need to be enabled. The LY6 is similar to the L96, but not identical. The L96 used different (higher fuel flow) injectors - so these parameters would need to be initially configured.
    To follow up with tuning the MAF and / or the VVE calibrations, you will need a wide band oxygen sensor.
    You may want to consider finding a more experienced tuner. This process is not impossible for a do-it-yourselfer, but it will require a great deal of self education - which may lead to periods of frustration.
    Best regards,
    Taz
    May 2011
    Thanks for the reply. I could not find a 2009 LY6 tune for that engine on tune file depot. I saw one from a 2007, but was not sure if it was going to be the same ECM OS, and also not sure if the 4 speed transmission would have any effect on the actual tune? I think that could be part of the issues with what my tuner did as he used a tune that originates from a different ECM OS. There are no real reputable tuners close to me. If I cannot do it myself, I think the best bet would be to do either some logs with a wideband, or an Autocal from a vendor. I have not heard back on how they obtain AFR with a Autocal however, is there a way to supply information from a wideband to it?
    I need to order a wideband, but want to make sure its able to be used with Autocal if I go that route.
    May 2011
    I am wondering if anybody can help me out here. I have been working with an reputable tuning company who many people vouch for via email and they can not seem to get it squared away either, Been working with them for 4 months. This is a stock L96 6.0, and it has much less power than my LC9 5.3 did despite all the work going into the tuning. They say my timing is pretty high, and I get poor mileage and lack of power still. I do not have a wideband connected as they say it is not necessary for my application (as it is stock), VVT has been logged and is operating as it should, the VVE tables appears to be a match to a 6.2 which must not matter too much, and my fueling appears to be close.
    Thoughts on things to start checking? I wish I could just find a 2009 2500 suburban with hopes of taking the tune from it but that just seems to be like finding a unicorn. I have since having codes pop up again, and its hard to say if tis the tune, or something on my truck as the codes are P1174 and P0430.
    Aug 2010
    Quote Originally Posted by Nver2loud View Post
    ... I do not have a wideband connected as they say it is not necessary for my application (as it is stock), VVT has been logged and is operating as it should, the VVE tables appears to be a match to a 6.2 which must not matter too much, and my fueling appears to be close ...
    Tuning without a wide band oxygen sensor may send you in endless circles. Your fueling is likely not close - see the DTC comments below.
    ... Thoughts on things to start checking? ...
    Impossible to say, without seeing the tune and a good log.
    ... I wish I could just find a 2009 2500 suburban with hopes of taking the tune from it but that just seems to be like finding a unicorn ...
    Any reputable tuner can program your E38 with this calibration. It requires the use of a Tech 2 or equivalent device (not tuning software).
    ... I have since having codes pop up again, and its hard to say if tis the tune, or something on my truck as the codes are P1174 and P0430 ...
    P0430 - is Bank 2 (passenger side) low cat efficiency ... either the cat is dead, or the tune is too rich, or the oxygen sensor isn't trimming, or ....
    P1174 - is Bank 1 (driver side) fuel trim cylinder balance ... points to poor fueling, or poor trimming, or ...
    May 2011
    I used to have an LC1, which had an analog narrowband output. Is this recommended to try to wire this into the system and put the wideband in one of the factory o2 bungs? If that is fine, and will not screw anything up I would gladly order one and do that. If not, can I manipulate the truck into running off a single o2 sensor somehow? or would I have to weld another bung into my factory manifold?
    I have attached the tune and log for viewing, I appreciate it.
    Let me know if anything stands out in specific? I have ordered new spark plugs and should be here tomorrow as the have 80k on this motor, I did not change them when I installed the engine.
    Thanks,
    Josh
    Aug 2010
    Thanks for posting those ...
    Could add these PIDS to those already being used, and relog please:
    - GM.AIRPERSEC
    - SAE.SHRTFT1
    - SAE.SHRTFT2
    The tune in post #1 is a 5.3L tune that has been modified in an attempt to run the 6.0L.
    The tune in post #9 has had segment swaps done to the Engine Operation and Engine Diagnostic segments.
    Do you have a copy of the original, unmodified, 5.3L tune ?
  1. L96 6.0 tuning issues
    By Nver2loud in forum Gen IV V8 Specific
    Last Post: November 10th, 2015, 09:29 AM
  2. Cant get 100% Throttle -Tuning E78 ECM 2011 GMC 2500 6.0 HD Truck L96 VVT non AFM
    By 496Stingray in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 2nd, 2015, 11:23 AM
  3. How to communicate with swapped pcm to tune?
    By FirstGenThree in forum Conversions / Aftermarket Parts
    Last Post: July 18th, 2012, 03:24 PM
  4. swapped engines not returning to 0 throttle
    By ls1mike in forum Gen III V8 Specific
    Last Post: April 20th, 2012, 01:49 PM
  5. Swapped MAFS, now weird issue
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2008, 05:25 AM
