Results 1 to 10 of 18
Thread: Novemeber 2015: EFILive Public Pre-Release
    Default Novemeber 2015: EFILive Public Pre-Release
    Please download and install both the V7.5 and V8 software packages.
    Both the V7.5 and V8 software were updated in this release, you must update both software packages.
    Release Notes:
    Whats New
    IMPORTANT
    The Auto-Lock implementation for E39, E92 and E98 controllers requires that tuners and customers upgrade their AutoCal and FlashScan firmware to V2.07.86 or later. The upgrade is required to prevent *.ctz and *.coz tune files created using this pre-release (or later) from being used with older software or firmware.
    Tuners: If you update your software and firmware and attempt to deliver new tune files to your customers, then your customers must also update to the following versions (or later):
    • V7.5 Software: V7.5.7, Build 288
    • V8 Software: V8.2.2, Build 281
    or they will not be able to flash those new tune files. Existing/old tune files will continue to work normally with the new software.
    Existing tune files will continue to work normally with the new software.
    Known Issues
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the Known Issues thread.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 297
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 288
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.93 (Nov 14, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Dec 2005
    Paul did you get my email and trace files I sent yesterday ?
    Thank You !
    www.mscservices.net
    Quote Originally Posted by GMC-2002-Dmax View Post
    Thank You !
    Yes.
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Very cool stuff. Thank you!
    Big on my request list is T87 OS# 24278443 and the E92 Commanded fuel DMA pids.
    The T87 OS keeps us current with 2016 Cars and Trucks and NOT having the E92 DMA fuel pids
    makes building MAF and VE tables tons of extra work without the ability to use calculated BEN factor pids
    for accurate changes....
    Kinda like today.... Tuning a Dodge Charger with HPT and using EFI LIVE to datalog serial wideband and then
    making my fuel changes across 2 totally different tuning platforms..... (anyone have the cute little smiley icon
    that projectile Vomits the green gook - to insert here???) Thanks Guy!
    The new feature and bug fixes are MOST APPRECIATED!
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    EFILive Distributor Trippin's Avatar
    May 2004
    This one?
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Jul 2003
    Quote Originally Posted by Chuck CoW View Post
    Chuck CoW
    You can easily create custom PIDs for the missing DMAs.
    g/Cyl
    Commanded AFR
    The good ones to add are the torque pid like the driver demand torque.
    Feb 2006
    Interesting, what do you mean. Ross says they are a headache to dig out... How do you just create a pid for commended afr?
    Chuck CoW
    Quote Originally Posted by Highlander View Post
    Really?
    Feb 2006
    Default You holding out on us????
    Really?
    Hey Ross!! You holding out on us????
    Pretending it's soooooo difficult???
    BTW, I tried a 2014 V6 camaro (E39A ??) and the DMA pid for commanded fuel was there, but not valid.
    Not sure how many there are per controller, but the commanded fuel pids would be the most important on
    my list cause without them the tuning gets messy and time consuming.....
    Chuck CoW
    Jul 2003
    Its so easy to log sae.lambda.
    Makes the dma pids not needed.
  1. Known issues with the Novemeber 2015 Public Pre-Release
    Last Post: November 17th, 2015, 09:50 PM
  2. Sep 2015: EFILive Public Pre-Release
    Last Post: October 28th, 2015, 09:24 PM
  3. Aug 13, 2015: EFILive Public Pre-Release
    Last Post: August 27th, 2015, 10:14 AM
  4. Aug 07, 2015: EFILive Public Pre-Release
    Last Post: August 12th, 2015, 12:46 PM
  5. June 02, 2015: EFILive Public Pre-Release
    Last Post: July 8th, 2015, 05:07 PM
