Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Novemeber 2015: EFILive Public Pre-Release
  1. #11
    I think he's ^ talking about the AFRATIO_DMA pids for E38, E67, E39, E92, etc.
  2. #12
    Jul 2003
    I know what he is talking about. I am saying he doesnt need them. The only exception might be(might!) if you are using e85.
    Otherwise a simple calc pid of sae.lambda*14.68 will suffice.
    Even on e92.
    Even on e85 its better to use lambda and not anything else.
    dma for afr are honestly a waste of time. There are other more important pids that we need. But i am sure everyone already knew all this.
  3. #13
    ^^ This seems like a very good solution as every GM ECM supports the sae.lambda PID without waiting for us do to the DMA PID's (note: I call them DAM PID's).
  4. #14
    Jul 2003
    That pid is supported since ls1b. Ls1b is called eqivratio
    this is why i said. Really?????
    finding those dma pids are sure a freaking pain in the a$$
  5. #15
    I prefer using SAE.LAMBDA over the other pids, I don't even convert to AFR at all, since WB is reporting in Lambda also, I just compare measured/commanded regardless of fuel alcohol content.
  6. #16
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default I don't see it....
    +1
    Hey Joe.
    I don't see it in E92. I do see EQ_RAT is that correct for E92? Lambda or AFR would work best.
    Thank you.
    Chuck
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
  7. #17
    Jul 2003
    E92 has SAE.LAMBDA
  8. #18
    I looked at a few 2015 E92 logs and they have SAE.LAMBDA.
  1. Known issues with the Novemeber 2015 Public Pre-Release
    Last Post: November 17th, 2015, 09:50 PM
  2. Sep 2015: EFILive Public Pre-Release
    Last Post: October 28th, 2015, 09:24 PM
  3. Aug 13, 2015: EFILive Public Pre-Release
    Last Post: August 27th, 2015, 10:14 AM
  4. Aug 07, 2015: EFILive Public Pre-Release
    Last Post: August 12th, 2015, 12:46 PM
  5. June 02, 2015: EFILive Public Pre-Release
    Last Post: July 8th, 2015, 05:07 PM
