Results 1 to 10 of 12
Thread: E38/T43 4wdlo signal, revisited
    Nov 2014
    Default E38/T43 4wdlo signal, revisited
    All,
    I retrofit Land Rovers with LS conversions. GenIV engine/6L80e trans/LT230 transfer case. (E38/T43) I have been slowing adding features to the conversion. Recently started building custom plug-n-play wiring harnesses for these applications. I currently have the E38/T43/BCM integrated. The last step is the 4wd low signal. My investigations have determined the 4wd low signal on the E38 ECM (X1, pin 2) is only functional if the vehicle came with a manual transfer case. No TCCM. This functionality seems to be compiled into the OS version or segment. EfiLive guys correct me here if I am wrong.
    I verified this with my 2007 GMT900 Silverado with a floor shift transfer case. So, I am after either an E38 OS or VIN number from a Silverado/Sierra, 2011+, 4wd, w/manual transfer case (floor shift). 4.8L/5.3L/6.0L/6.2L With a VIN, I can get the OS from SPS.
    Any help here is appreciated.
    Feb 2012
    Has this option of using a manual transfer case OS or even just that segment been used to breach this obstacle yet?
    Nov 2014
    Yes, I verified functionality with and OS for a floor mounted transfer case shifter. Ground the signal for low range.
    Mar 2009
    Is the BCM required to make this work?
    Nov 2014
    No, use pin 2 on connector X1 of the E38.
    Feb 2012
    Default 4 low
    Quote Originally Posted by nmarkiw View Post
    Sorry for the lack of clarity, can one just use the segment with the Manual TC or would one need to use the entire OS?
    Reason I am asking is I will have the BCM but not the TCCM, I will be using an OE Cluster however.
    Mar 2009
    Thank you sir!
    So a Manual TCM OS and X1 pin 2 is the ticket. Cool.
    Jan 2018
    Quote Originally Posted by LastCall View Post
    Thank you sir!
    did the OS swap work for you? Im pretty new to this. how did you figure out which OS to use? Thanks
    Mar 2009
    Quote Originally Posted by theshop_steven View Post
    I never got around to trying it.
    Nov 2014
    BBtech,
    As far as I know, you have to change OS. My understanding is this function is compiled into the OS. The BCM will still work with this new OS.
    Someone else will have to chime in regarding if just a segment change is possible. There is no switch to enable this.
  1. T43/E38 Scaled Shifting
    By Webbs in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 17th, 2015, 02:09 AM
  2. E38 Street Sweeper no start / no crank signal
    By Boost in forum E37, E38 & E67 PFI ECM's
    Last Post: September 11th, 2013, 05:11 AM
  3. Can BBL log E38 and T43 at same time?
    By zbadestz in forum FlashScan V2 BB Logging
    Last Post: May 6th, 2012, 01:13 PM
  4. PIDs for E38 & T43
    By mr.prick in forum Gen IV V8 Specific
    Last Post: June 9th, 2011, 09:33 PM
Tags for this Thread
