Results 1 to 3 of 3
Thread: RAFIG not Valid? Can't find underying PIDs
    Oct 2003
    Default RAFIG not Valid? Can't find underying PIDs
    When I add PID:
    -- CALC.RAFIG
    return pid("IAC_LTD_DMA")+pid("IAC_STD_DMA");
    I can't find the underlying PIDs to create the calculation. What could I be doing wrong?
    Idle Airflow Correction AC Off, In Gear {CALC.RAFIG}
    Expression:
    Grams/s = {GM.IAC_LTD_DMA.gps}+{GM.IAC_STD_DMA.gps}
    is NOT valid because:
    Required parameter {GM.IAC_STD_DMA.gps}, at position 42 is not selected.
    PID value cannot be determined because
    the following error would occur:
    Expression not valid: Required parameter {GM.IAC_STD_DMA.gps}, at position 42 is not selected.
    Expression:
    Lbs/Min = {GM.IAC_LTD_DMA.lbpm}+{GM.IAC_STD_DMA.lbpm}
    Expression not compiled
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Oct 2003
    Wait ... I find it in EFILive Scan, but not in the PID selection for BBX.
    Oct 2003
    Are {GM.IAC_LTD_DMA.gps}+{GM.IAC_STD_DMA.gps} mislabeled to IAC_LD_DMA and IAC_SD_DMA in the BBX?
  1. E92 DMA PIDS Not Valid
    By Ninety8C5 in forum Black Box Logging
    Last Post: February 7th, 2016, 01:44 PM
  2. Can't Find PIDs Selction
    By FreshDA9 in forum Gen III V8 Specific
    Last Post: June 6th, 2013, 03:17 PM
  3. cant validate rafig pids
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2010, 04:58 AM
  4. AutoVE when critical PIDs aren't valid?
    By ScarabEpic22 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2009, 02:38 AM
  5. Valid & non valid pids
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2006, 09:22 AM
