Does anyone know for sure how to calculate small pulse correction from injector flow data like below? I'm running very low pulse widths on Lucas 120lb injectors and being off a little makes a big difference, so I had them tested. I'm guessing this is what needed using 2ms as an example is:
since 2 is 20% of 10, 2ms should theoretically flow .0392 (.196x.2=.0392)
.030 was measured which is 30.7% less than .0392
so the correction at 2ms should be .614, because the table shows 2.0ms rather than .002 (.002+30.7% is .002614)
does that sound right?
vol/squirt
ms cc
10 0.196
8 0.153
6 0.111
4 0.070
2.00 0.030
1.90 0.030
1.80 0.028
1.70 0.025
1.60 0.022
1.50 0.019
1.45 0.018
1.40 0.018
1.35 0.018
1.30 0.017
1.25 0.017
1.20 0.016
1.15 0.015
1.10 0.015
1.05 0.014
1.00 0.013
0.95 0.012
0.90 0.010
