Results 31 to 37 of 37
Thread: Help setting up wide band to log.
  1. #31
    Nov 2015
    Ok,
  2. #32
    Nov 2015
    Hi Joe, playing with fuel psi set up now. here are pics of my set up. ignore the ngk pic. There are no units showing up in the fuel pressure pid. not sure why. thanks.
ID:	19073   Click image for larger version.
ID:	19070   Click image for larger version.
ID:	19071   Click image for larger version.
  3. #33
    Quote Originally Posted by LSXRacer View Post
    Ok, close...
    The string "*CLC-00-001" has to be on a line by itself, for example:
    Code:
    *CLC-00-001
    psi         0.0      100.0         .1    "{EXT.AD2}*25-12.5"
    Then you also need units, they go at the start of the next line.
    Then, those same units (exact same spelling/case) are used in the RPN section:
    Code:
    CALC.FP           F001   CLC-00-001        psi          Fuel     "Fuel Pressure"
  4. #34
    Then, not documented, you should leave at least 2 blank lines at the end of the file, otherwise the scantool does not correctly display the description string.
  5. #35
    Nov 2015
    thanks Joe. everything is working now. thanks again for all the help.
  6. #36
    May 2016
    Hi JoeCar,
    Lets say I follow this, which makes sense to me:
    PLX's analog output:
    - connect PLX analog signal and ground to FSV2 AD1+ and AD1- respectively;
    - in V7 scantool select pid EXT.AD1 and CALC.AFR_PLX1 to log.
    How do I PLOT AFR ERROR in any MAP(table)? E.g. I set up a map table that has a column of Air Flow Rate from mass Air Flow Sensor and ROW of MAFFREQ2. So for Data.....what do I select?
    if I select WideBand AFR 1 - PLX (AFR)... I plot the wideband AFR correct?
    Thanks in advance.
  7. #37
    Quote Originally Posted by smithers View Post
    Hi JoeCar,
    Correct.
    And if you have an E38 you would also select pids E38.AFRATIO_DMA and CALC.BEN_PLX1_E38.
    To see how to create a map, see this:
    How%20to%20Create%20a%20Map.htm
    basically:
    - you goto the tunetool table (B0101 or B5001) and highlight the whole table, and do rightclick->Copy-with-Labels;
    - you then goto the scantool map properties, and under the Row and Column tabs you do Paste Labels;
    - then on the Row and Column tabs you select the pids for the table axis's;
    - then on the Data tab you select the BEN pid.
    Thanks in advance.
    You don't need to plot wideband AFR... you want to plot the BEN pid.
  1. Newb Setting up serial Wide band
    By HellKnightHicks in forum General
    Last Post: January 16th, 2013, 12:30 PM
  2. I need help with my wide band
    By isak81 in forum External A/D inputs
    Last Post: January 8th, 2012, 03:46 PM
  3. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  4. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
  5. lm-1 wide band
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 08:39 AM
