Results 1 to 10 of 10
Thread: Fuel Temperature Density Correction
    Feb 2007
    Default Fuel Temperature Density Correction
    You don't find many forum posts regarding fuel temperature density correction.
    Fuel density changes ~5.5% over a range of 50°C (, -10,1.0277, 0,1.01662, 10,1.00554, 20,0.99446, 30,0.98338, 40,0.9723)
    I guess the trims cope adjusting fueling to account this difference, from season to season it would explain if trims are going positive in hot weather, negative in cold weather.
    The injector flow modifier for IAT seems to be the candidate for making corrections for fuel temp, its generally set at 1 for all temps, but Ive seen the LS7 or LS9 with different values at high IAT, factor <1, it looks as thou reducing flow to compensate for less dense air, I thought MAF or GMVE would calibrate for this? So i think it must be to compensate for less dense fuel.
    The IAT modifier is linear with change in fuel density as below, graph attached
    T*___LS9_______Change in Fuel Density
    40___0.986024__0.9723
    50___0.971986__0.96122
    60___0.961976__0.95014
    70___0.95398___0.93906
    80___0.947999__0.92798
    Normally minimum IAT would be equal to ambient, or higher, so using the below values would compensate for change in fuel density <1 as fuel temps increase, density decreases, >1 as temps decrease, density increases. Fuel density is normally shown at 15°C which would be factor 1.
    (, -40,1.06094, -30,1.04986, -20,1.03878, -10,1.0277, 0,1.01662, 10,1.00554, 20,0.99446, 30,0.98338, 40,0.9723, 50,0.96122, 60,0.95014, 70,0.93906, 80,0.92798, 90,0.9169, 100,0.90582, 110,0.89474, 120,0.88366)
    Any thoughts, being done already?
Name:	LS9 IAT modifier vs Change in fuel density.jpg
ID:	19062   Click image for larger version.
Name:	LS7 IAT modifier.jpg
ID:	19059   Click image for larger version.
Name:	LS9 IAT modifier.jpg
    Last edited by Gelf VXR; December 6th, 2015 at 09:27 PM. Reason: Updated as per my understanding
    Oct 2006
    Fuel temperature with a return-less system would be closer to ECT than IAT I would have thought. But it is a good question non the less.
    The Tremor at AIR
    Aug 2013
    Quote Originally Posted by 5.7ute View Post
    I think you're right. My fuel system is return-less and I don't see any difference between winter and summer.
    Oct 2006
    Is this for cold start enrichment after start up?
    ECT, IAT and 1,2 or 3 Bar MAP
    2006 Trailblazer
    Feb 2007
    I'm curious to see if there is a modifier for fuel temp density, for all temperature conditions. Trying to get idea from old logs
    When I'm looking at the log sat at idle OL SD, average Charge Temp 87°C, IAT 71°C, DYNAIR = 8.56 g/sec, 800RPM, WB EQR average 1.0002, stoich is AFR 14.7, average IPW 1.581ms.
    8.56 g/sec divide by 14.7 = 0.5823 g/sec calculated fuel flow.
    However, when i compare to my calc.pid for fuel flow using stock LS3 injector data
    Inj Flow Base (VAC referenced) * IPW * 800 / 1500 = 0.6443 g/sec,
    This why I'm thinking there isn't a modifier, the fuel flow g/sec calculates a lot less than expected, by a factor 0.904
    If fuel density was referenced at 0°C rather than 15°C, a rise of 70°C would be a factor of .923. using density data i used for petroleum products.
    It would support the idea no modifier is used.
    More research required.
    I'm also curious as how the temperature Bias for OL speed density is referenced when the MAF removed (or in my case disabled), the value is normally referenced from B0115, airflow from the MAF sensor. I had set my MAF tables also to 1g/sec for all Hz. So how accurate is DYNAIR in this case?
    Oct 2006
    Where are you getting IPW from in your calcs?
    The Tremor at AIR
    Feb 2007
    where are you getting ipw from in your calcs?
    gm.injpwb1/b2
    Oct 2006
    Remember you need to remove the offsets for any calculations to work :-)
    The Tremor at AIR
    Feb 2007
    Ahh,
    I looked up injector flow MAP correction at MAP ~37kPa/ VAC~64kPa & volts 14v = 0.8 ms, small pulse adjust around 1.5ms = -0.05ms
    1.581 - 0.8 - (-0.05) = 0.831
    5.67 * 0.831 * 800 / 15000 = 0.2513 g/sec
    I did something wrong?
    My calc.pid which was for fuel economy, it doesn't matter really, better a simple calc.pid for fuel flow from corrected airflow for economy
    Feb 2007
    Just come across this tutorial from Swingtan, pages 7, 8 and 9 on IAT B1213 calibration
  1. Help with B5908 Fuel Mixture Spark Correction
    By TrendSetter in forum Gen III V8 Specific
    Last Post: March 26th, 2014, 05:57 AM
  2. CO3 Speed density 2 bar temperature modifiers?
    By zapp168 in forum Custom Operating Systems
    Last Post: October 21st, 2010, 08:47 AM
  3. Fuel temperature affects mpg?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2009, 04:55 PM
  4. Speed Density Charge Temperature Blending (E40)
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: June 28th, 2008, 04:36 PM
  5. Thoughts on not using Fuel Mixture Spark Correction
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: January 18th, 2008, 02:30 AM
