Results 11 to 20 of 38
Thread: Beginner help with LML tune
    Dec 2015
    Quote Originally Posted by IdahoRob View Post
    Start with the peddle position to desired torque tables. Make small changes and test. This will help the dead peddle issue with stock trucks.
    Thanks to you too IdahoRob, advice is much appreciated.
    Mar 2009
    If I had any LML experience i would help yu out, but I haven't even touched one yet(and quite honestly have no desire to). I've done 01-010 diesels, and have a decent grasp on them, but thats as far as I've gone. We all started somewhere though. Like said above, don't take all the labels to heart as some functions don't do exactly as described, or they also work with other tables not listed. The LML has proven to be a fickled demon, even for experienced tuners who do this everyday they have proven to be troublesome. Just remember what works for one truck, may not transfer over to another as each LML seems to be a bit different. The best description of the LML I have been given is they are all like snowflakes. They are all the same, yet all different. Hence why I like my LB7, it does exactly what I tell it to, nothing more, nothing less. LLY's can be another story, LBZ's aren't to bad, and LMM's have oompteen dozen limiters, and hidden tables for idle, nuetral, and so on that don't always make sense.
    Aug 2008
    Do you have your stock file to start with? If so go to pedal position to torque and and 10 percent up to 50 mm3. Then blend the next four cells up. You should notice a difference in throttle response.
    Dec 2015
    Quote Originally Posted by S Phinney View Post
    Is this where you're talking about (pic)?Click image for larger version.
    Aug 2008
    Yes that is it.
    RacinTJ, where do you live?
    Custom Tuning Services
    Dec 2015
    Florida. Why?
    Aug 2008
    Where at in Florida? I'm in the Tallahassee area.
  9. #19
    Dec 2015
    Central FL. Lakeland.
  10. #20
    Dec 2014
    What do you consider a mild tune?For more power your going to want to add some fuel and mess with the timing.
  1. LML stock tune
    By SEPPY in forum Duramax 2011+ LML / LGH
    Last Post: March 4th, 2016, 04:24 AM
  2. LML Smoke Tune
    By Tristanhuerta in forum Duramax 2011+ LML / LGH
    Last Post: June 30th, 2014, 09:50 AM
  3. LML TCM Tune
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: November 15th, 2010, 05:52 PM
  4. beginner / need help
    By sharpshooter in forum FlashScan V2
    Last Post: December 3rd, 2009, 06:44 AM
