Results 1 to 5 of 5
Thread: Simulated o2
    Senior Member Naf's Avatar
    Aug 2006
    Default Simulated o2
    I installed dual Wideband from Innovate in my car. I programmed the analog 1 outputs properly showing 450mv as 14.7, but when i checked it from the ecm its showing me a 460-507mv and it keeps moving around instead of sit steady. The key is in the on position, but the engine is off. I programmed the analog 1 out puts to give 450mv at warmup and 450mv for error.
    I disconnected one sensor and left the other so i may get a steady 450mv and see a lean reading from the other but like i mentioned above, i am getting a variance of numbers that is not 450.
    Should i program the WB02 to reflect this variance and have the average 450?
    American Muscle, European Design, Japanese Tactics
    Can you post a screenshot from the LM Programmer software showing how the analog channel 1 is programmed...
    it should be a steep reverse step.
    Aug 2006
    I know the numbers
    .909 is 11.50
    0.055 is 17.40
    .450=14.7
    Htr and error are .450
    I had a e2 and my mv should have been .450 but instead was .460/.464/.507
    Aug 2006
    It was a poor ground issue, so i swapped the WBo2 to be down stream and i installed NBo2 upstream. I then did not use the analog output from the innovate. I merely disabled the sensor 2 settings.
    Ok, thanks for the update.
  1. LC-1's simulated narrow band
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: January 18th, 2008, 03:22 AM
  2. Simulated Narrow Band with LC-1 on an LS2??
    By Rocketman69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2007, 12:35 AM
